Crimper Tool ???
- kzdcw
- 77' KZ1000A
Crimper Tool ???
07 Oct 2014 04:10 - 07 Oct 2014 04:11
Purchasing a batch of 3.5mm "bullet" ( male/female ) connector terminals. For 14-18 gauge wire. What Ratcheting Crimper do you guys recommend without breaking the bank to get that Factory Look ? Rewiring my 77' KZ1000.
77' KZ1000A
Last edit: 07 Oct 2014 04:11 by kzdcw.
Re: Crimper Tool ???
07 Oct 2014 05:41 - 07 Oct 2014 05:48
CylceTerminal.com has a green ratcheting crimper that's probably about as inexpensive as you can expect. They also have a nice terminal pin extractor tool set --- very handy to have.
Crimper Tool page
I already had a Harbor-Freight ratcheting crimper, but the die set was incorrect for open barrel terminals, so I got the correct dies at Amazon.com. The 2 together cost about the same as the crimper from CycleTerminal.
Crimper Tool page
Last edit: 07 Oct 2014 05:48 by martin_csr.
- kzdcw
- 77' KZ1000A
07 Oct 2014 08:00
Martin, We have a local HF. Could you show me what Dies you purchased off of Amazon?
77' KZ1000A
07 Oct 2014 08:22 - 07 Oct 2014 08:23
This set fit the HF tool perfectly.
Amazon.com --- Aircraft Tool Supply --- Open Barrel Crimper Die Set .
There's also a Klein tools die set that will probably work --- it's a little cheaper.
Last edit: 07 Oct 2014 08:23 by martin_csr.
- kzdcw
- 77' KZ1000A
07 Oct 2014 08:58
Martin, These are the connectors I purchased. Will the HF crimper or crimper from Cycle Terminal do "Both" bullet male/female ends?
Attachment _12-2.jpg not found
77' KZ1000A
- loudhvx
07 Oct 2014 11:19
At those prices, it will be much more convenient to have two crimpers. One for closed-insulated barrels, and one for open barrel. You don't want to get stuck on a job swapping dies every 5 minutes. (Although, you will get good at it
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- kzdcw
- 77' KZ1000A
07 Oct 2014 15:01
Loudhvx, Could you explain to me how these crimpers work? Do the crimpers close the open end on the male and female connectors or do the crimpers close the end of the connectors where the wires connect too? Never used them before, but want to make sure I get the "Right" crimpers needed for the job.
77' KZ1000A
07 Oct 2014 18:41 - 07 Oct 2014 18:49
The open barrel crimper curls the open ends of the terminal pins inward onto the wire and the insulation to kinda form the letter M. The best way I can explain is to put your finger tips together, then curl them in --- that's sorta what the crimper does to the terminals.
CycleTerminal -- Crimp tool help page
Note: match the correct size terminal pin to the correct size wire. Otherwise, you may not get a good/proper connection.
Last edit: 07 Oct 2014 18:49 by martin_csr.
07 Oct 2014 19:23
Like this....
Attachment 00003b_2014-10-07.jpg not found
- loudhvx
07 Oct 2014 21:55 - 07 Oct 2014 21:58
It's a beautiful thing to watch when it all works right. (But get a crappy one and it looks like someone had a drunken possum bite down on the thing. Best to get a good one... crimper that is, not a possum.)
Oh, and for anyone making harnesses, do yourself a huge favor and get a big roll of non-adhesive electrical tape. You can get it on ebay. Wrap most of it with non-adhesive, then finish the ends with adhesive tape. For whatever reason, the non-adhesive stuff is more expensive, but worth every penny if you ever have to unwrap it.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 07 Oct 2014 21:58 by loudhvx.
08 Oct 2014 05:06 - 08 Oct 2014 05:15Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
