indexing rod for CRANKSHAFT
- peter1958
15 May 2014 14:14 - 17 May 2014 02:08
Anyone know where I can get a 17mm indexing rod.
www.kzzone.com/
Last edit: 17 May 2014 02:08 by peter1958. Reason: so others can search
- 4TheKZ1000
Re: indexing rod for CRANKSHAFT
15 May 2014 14:47 - 28 May 2014 14:58
indexing rod for camshaft
that is crankshaft Einstein...... :woohoo:
Last edit: 28 May 2014 14:58 by KZQ.
- peter1958
15 May 2014 15:07 - 28 May 2014 14:59
yeah :woohoo:
www.kzzone.com/
Last edit: 28 May 2014 14:59 by KZQ.
- zed1015
15 May 2014 15:15 - 28 May 2014 14:59
No eBay APP ID and/or Cert ID defined in Kunena configurationHere.
This will do the job.
17mm ground bar.
17mm ground bar.
- peter1958
15 May 2014 16:35 - 28 May 2014 14:59
Order`d that one thanks. Shipping was more than rod but owell
www.kzzone.com/
- steell
15 May 2014 22:10 - 28 May 2014 14:59
17mm drill rod from Grainger, McMaster Carr, etc, no shipping if you pick it up at a Grainger store.
- racer54
17 May 2014 06:09 - 28 May 2014 15:00
Last edit: 28 May 2014 15:00 by KZQ.
- peter1958
17 May 2014 17:04 - 28 May 2014 15:00
As usual I do not have time to wait and went and bought one from England and spent a few bucks, I work a lot and do not have time. Hope this thread helps someone later to get one much cheaper than i did, Thanks eveyone for your help. I had reserched or looked for this in the forum and found nothing .Thats why i changed it from camshaft .... just did it if others look and find this thread for help
www.kzzone.com/
- racer54
17 May 2014 21:35 - 28 May 2014 15:00
We have all been there and done that....
- zed1015
18 May 2014 10:43 - 28 May 2014 15:01peter1958 wrote: Order`d that one thanks. Shipping was more than rod but owell
I just posted that link to show what would be accurate enough and suitable for the job.
Was there not a US Ebay supplier for the ground bar ?
Last edit: 28 May 2014 15:01 by KZQ.
- peter1958
18 May 2014 11:08 - 28 May 2014 15:01
Not your fault. I just should have waited for a little before I went and bought it. Could have got up and drove to Paul b Zimmerman and picked one up there but after working all week i just want to get things done and just get it online.No big deal .
www.kzzone.com/
- peter1958
28 May 2014 13:48 - 28 May 2014 15:01Got the rod yesterday and had a chance to go over tonight and it went through all so Crank is fine. Could`nt really look at the height of the pistons when I took the head off because it came off so easy and was not tight. Any how I don`t have time to put my welded crank in so this is good news. Larry has the head and I am just so glad he does. Cause this is going to rock when done. This is my everyday ride or when ever I get a chance. Colorado here we go!
www.kzzone.com/
