Kawasaki GPz 1100 b2 -1983
- andreano
14 Mar 2014 12:53
hi i'm new here i've just bought an 83' kawa GPz 1100 b2 .
Please can someone share or help me found and user an manutention manual?
i'm writing from italy sorry if my english is a little bit rusty, is ok if the manual is in english or better in italian, but on internet i found only the german one.
thx for ur precius time.
- barney
Re: Kawasaki GPz 1100 b2 -1983
14 Mar 2014 13:07
B2 refers to a 1982 GPZ. Maybe check again what year GPZ you have.
- Mcdroid
- Gone Kwackers
14 Mar 2014 13:30
barney is correct...if you have a 1983 model, then you have a ZX1100-A1, not a (K)Z1100-B2 (1982) model. Both are commonly called GPz1100's. The motors are similar but much else is very different between the two models. If you have the 1983 ZX model, then you'll need two manuals...the base manual and the ZX supplemental manual. If you have the Z1100-B2 model, then you'll only need one manual (the base manual).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- andreano
15 Mar 2014 11:38 - 15 Mar 2014 11:45
I checked on the registration document says it was registered in 1983
but comparing the information in my possession and a lot of pictures and documents on the Internet is a GPZ 1100 B2,
to help you understand the registration document shows the displacement of 1090cc,engine type KZT 10 BE,
There is no front fairing
The front headlight is rectangular and not round
on the tank close to the saddle there are two grooves the shape is similar to a rectangle not ellipse .
I wanted to ask you one other information my bike is painted all black, on the internet I found pictures showing this coloration, but not a single document ,most of that reports that the common paint is red or red with gold,
the question is is normal that the pain is all black? You thinck that is the original coulor? :blink:
Last edit: 15 Mar 2014 11:45 by andreano.
- Mcdroid
- Gone Kwackers
16 Mar 2014 05:45
Without seeing a photo, it sounds as though you have an early model GPz1100...the fact that it is missing the front fairing, suggests you might even have a 1981 model, which came without a fairing. The information on the frame will indicate what year/model you have, not the engine VIN. The frame VIN can be checked against several on-line lists for model/year determination...or you can post it here and someone will ID it for you. BTW, in Europe, the 1981 GPz1100 came in red, the 1982 came in red and in gold, never in black. Yours had been repainted.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: andreano
- andreano
16 Mar 2014 08:09
Ok when i come back at home i'll see this information and than i'll report here thank you very much for your help, sorry for my dumbness but i'm approccing now to this new fantastic world :woohoo:
- Old Man Rock
16 Mar 2014 08:19 - 16 Mar 2014 08:22
FREE GPZ1100 Service Manual!
Select language of choice, english version downloaded just fine....
www.pdfmotomanual.com/
www.pdfmotomanual.com/index.php?r=site/p...K&make=1058&lang=ENG
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 16 Mar 2014 08:22 by Old Man Rock.
- ed spangler
- Tennessee Z
16 Mar 2014 09:17 - 16 Mar 2014 09:17
Claro!
Please Call Z1 Enterprises Marion,N.Y.
They also have a facebook page and website.
They can help you find your manual!
Bienvenidos Senor
Chao
Eduardo
Bienvenidos Senor
Chao
Eduardo
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Last edit: 16 Mar 2014 09:17 by ed spangler. Reason: spelling
- andreano
16 Mar 2014 13:11
by the way the frame number is kzt10b0081++ , i read on the internet that is referred to an 81' type?!..
so i have to assume that is a gpz 1100 b1 is that correct? :blink:
wow ok.. so i have to serch for a user manual of GPz 1100 81'... correct me if i'm wrong
- Mcdroid
- Gone Kwackers
16 Mar 2014 13:43
Yes, you have a 1981 GPz1100 also called a Z1100-B1. You need a single base manual...either of these will work:
Kawasaki Service Manual Part Number 99924-1026-01 or 99924-1026-02. Both are available used on eBay...both are available as reprints from www.e-classicbike.com and at least one of the above (perhaps both) is available as a free pdf download (not sure of the website).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- daytonwindow6
13 May 2014 20:24
thanks for all suggestions and ideas you've shared... :laugh:
- MFolks
13 May 2014 20:38
www.wemoto.com/bikes/kawasaki/gpz_1100_b1/81-82/
www.repairmanual.com (Use # 99924-1026-03 for Kawasaki 1981-2005 Kz/Z1000 Factory Service Manual)
