Kawasaki ring compressor
- Jeff.Saunders
Re: Kawasaki ring compressor
13 Apr 2015 15:02
I may have a spare 57001-532 in my tool chest. I received a couple of the factory ring compressors with bikes I've purchased over the years. I think the spare is a -532 and not -112.
I also have a KZ650 ring compressor that I will never use.
- missionkz
13 Apr 2015 15:14 - 13 Apr 2015 15:17
I'd be very interested.....
I'd also consider making mine (for a 900) available to members for the cost of shipping and a reasonable, refundable deposit....plus a guarantee it will be returned!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 13 Apr 2015 15:17 by missionkz.
- zukdave
13 Apr 2015 15:53
Jeff post that 650 compresser on the KZ650 Info. site it'll sell.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- missionkz
13 Apr 2015 17:17
That's cool... some of these tools for a few of us are one time use only!
That's why I need that kz1000 ring compressor instead of the Z1, KZ900! LOL.
Bruce
1977 KZ1000A1
1977 KZ1000A1
- Brady 154
04 Feb 2016 13:01
I'd love to have one of these. Anybody have one for sale?
1976 KZ900 LTD, resto-mod
-1075 Piston Kit
-PSP 3X Cams (degreed to 106)
-Mikuni RS34 Carbs
-Pod Air Filters
-Dyna S Coils and Ignition
-Race Tech Valve Cartridge Emulators up Front
-Ohlins Shocks out Back
-1075 Piston Kit
-Mikuni RS34 Carbs
-Pod Air Filters
- peter1958
04 Feb 2016 15:31
I have one for the 650 i can live without
www.kzzone.com/
- Brady 154
05 Feb 2016 04:25Darn, i don't think that'll work. I have a 1000, so I need the 72mm one.peter1958 wrote: I have one for the 650 i can live without
-1075 Piston Kit
-Mikuni RS34 Carbs
-Pod Air Filters
-1075 Piston Kit
-Mikuni RS34 Carbs
-Pod Air Filters
- KZB2 650
05 Feb 2016 06:37Brady 154 wrote:Darn, i don't think that'll work. I have a 1000, so I need the 72mm one.peter1958 wrote: I have one for the 650 i can live without
The problem is as soon as you go bigger 1075, 1105 etc or 700cc or 810 on mine they don't work either..... I was seriously thinking about one too till I read and figured out that.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- missionkz
05 Feb 2016 22:24KZB2 650 wrote:Brady 154 wrote:Darn, i don't think that'll work. I have a 1000, so I need the 72mm one.peter1958 wrote: I have one for the 650 i can live without
OK... my factory Z1 900 ring compression tool did not work well on my 1015cc pistons and it didn't work AT ALL on my 1075cc pistons.
So I sold it, the piston stabilizing rods and the big orange bag/case.
I have shown pictures of this problem before even trying it on the engine....here on the KZR site and those photos can be found if looking around.
However, my factory KZ1000 ring compressor worked flawlessly, and even with my 1075cc over size pistons!!
The damn cylinder block just slid down over the four, 2mm over sized pistons and rings so fast, it actually caught me off guard.
So fast, I couldn't slow it down in time to watch what was happening...the sleeves just slipped right down and banged into the compression tool in one smooth motion.
No damage or anything,
I just wasn't really ready for it to go together that fast.
With the tool removed, (EASY) the block pushed right down with little effort and bottomed out into the locating dowel pins.....
Plus, taking the tool apart after this is just a joy, so satisfying.... compared to trying to do it with all the nutty contraptions, hose clamps, beer cans, plastic wire ties (you name it) I've seen them all.
The entire procedure took 4 minutes after squeezing the rings and that included removing the tool from the case and studs.
Bruce
1977 KZ1000A1
1977 KZ1000A1
06 Feb 2016 03:37
Sounds great. I always dread putting the barrels back on. PITA I don't do it enough to warrant buying one though. Just curious, what do they cost now?
- daveo
09 Feb 2016 18:14 - 09 Feb 2016 18:23missionkz wrote: so satisfying.... compared to trying to do it with all the nutty contraptions, hose clamps, beer cans, plastic wire ties (you name it) I've seen them all.
First attempt, and was a joy too. A cheap one... :lol:
The black plastic strip is slick. It gets pressed down the piston by the bottom of the cylinder sleeve as it presses on the edge of the strip. The rings pop free inside the sleeve where they should, with the gaps locked in their proper positions. You don't get that using fingers to compress the rings.
1982 KZ1100-A2/1170cc sleeper 😀
Last edit: 09 Feb 2016 18:23 by daveo. Reason: none
The following user(s) said Thank You: GPz550D1, Patton
- JDRAKE4200
28 Feb 2017 19:59
What is the plastic? What's it from/for?
Keep the shiny side up!!!!
1976 KZ900 LTD
2004 Sportster 1200 Custom
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
