Oil Seal guides...Do I need'm?
- recez
- 74 kz400 D
20 May 2013 22:48
So I'm going to replace my clutch cable at some point..hopefully sooner than later. As I read through the manual I see that they say to use the Shift Oil Seal Guide 57001-264 NOS. So I go and try to find one, without much luck...partzilla said they sold them but in the end they couldn't get them in stock, I couldn't find one on ebay either. My question is are these oil seal guides imperative for these kind of repairs? i have found the kick shaft oil seal guide 57001-265 which I purchased on ebay for 30 bucks. What should I do for this shift shaft guide... do you guys use them or is there some sort of aftermarket part I can buy which would be cheaper and easier to find? I'm really not sure what the guides do other than hold the seal in place when you reinstall.. I guess when I do the above mentioned repair I'll find out just how necessary they really are (I really don't want a oil leak somewhere that wasn't leaking before the repair). Suggestions would be appreciated
74 kz400 D cafe
- Nebr_Rex
Re: Oil Seal guides...Do I need'm?
20 May 2013 23:16
How's about a pic of said seal?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- recez
- 74 kz400 D
21 May 2013 00:01
well I don't have a picture... but here is a link to something similar This is part number 57001-266 I need 57001-264...lol. If you don't mind take a look. Should I wait until I have this part?
Nebr_Rex wrote: How's about a pic of said seal?
74 kz400 D cafe
- car5car
- Banned
20 Aug 2013 22:59
socket
96 Yamaha Royal Star
82 Yamaha Virago 920
- Motor Head
20 Aug 2013 23:54
No i would say you should not need any special guide tools. Use a lube, like Sil-Glide, or Vasiline, on the sealing surface to help it slide together. On the sprocket seal, you can use a small pick, or screwdriver to help start the seal.
