ever wonder what the temp at 55mph when its 70 deg
  • ramtough_63
  • ramtough_63's Avatar Topic Author
08 Jan 2013 23:24
#566457
Attachment 226678_10151243822258740_567135253_n.jpg not found
dont know how true it is picked it up from a different sitr
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • testarossa
  • testarossa's Avatar
Re: ever wonder what the temp at 55mph when its 70 deg
09 Jan 2013 00:49
#566470
Looks about right to me.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
09 Jan 2013 11:41
#566526
Yep...I checked mostly at the 90-100F range...which is what it is here 9 months of the year :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • testarossa
10 Jan 2013 09:07
#566677
Mcdroid wrote: Yep...I checked mostly at the 90-100F range...which is what it is here 9 months of the year :laugh:
Looks like it needs a couple more columns for OMR! :)
2004 ZX-10R
Angola, IN
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
10 Jan 2013 11:10
#566685
Why would it feel even hotter when you are going 60 in 100F air temps? Am I reading the chart wrong?
Build Thread
  • ramtough_63
10 Jan 2013 13:55 - 10 Jan 2013 13:56
#566702
tachrev wrote: Why would it feel even hotter when you are going 60 in 100F air temps? Am I reading the chart wrong?
starts working like a covection oven somewhere around 95 it seems
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Last edit: 10 Jan 2013 13:56 by ramtough_63.
  • upncummr
  • upncummr's Avatar
10 Jan 2013 19:03
#566746
I would have expected to see either a linear relationship or an exponential relationship between the increase in speed and the decrease in the perceived temperature. I also would have expected that relationship to hold steady over the speed range shown.
Using the 30 degree column as an example:
Add 5 MPH, lose 3 degrees.
Add 5 MPH more, lose 11 degrees more.
Add 5 MPH more, lose 7 degrees more.
Add 5 MPH more, lose 5 degrees more.
Add 5 MPH more, lose 4 degrees more.
And on and on.
I can certainly understand why you begin to lose greater amounts of heat as you move up from ) MP to 5 MPH to 10 MPH; but I don't understand exactly why that perceived heat loss begins to slow down as you continue gaining speed. The only thing I can think is that beyond a certain speed "cold is cold" and you're no longer able to perceive it getting colder and colder as you approach zero degrees and lower.
Gary
  • jcasterline
  • jcasterline's Avatar
10 Jan 2013 23:43
#566794
I think that as your speed increases, some of the air is moving with you. A pocket of air to serve as a temperature buffer. Maybe that's just where my mind goes.
1982 kz 650 CSR mostly stock.
  • testarossa
11 Jan 2013 12:06
#566846
P
I wouldn't expect everyone to understand this but it is a heat transfer equation at work. What you should notice about the chart is that the break point between feeling cooler or hotter happens at your body temperature. So when the air temp is lower that your body temp then the wind is stripping heat away from your body making it feel colder. Above 98.6 degrees air temp the wind is warmer therefor adding heat to your body.
The greater the difference between the air temp and your body temp means that the wind is more able to take heat away or add it. Wind speed also magnifies the rate of heat removal or addition. It might be hard to understand but heat is like water in a sense. It will move to even itself out just like a body of water will self level. Put two bodies with different temperatures in contact and eventually the heat will transfer from the warmer to the cooler until they become the same temp. In this case the wind and your body are those two things. I hope that makes sense.
2004 ZX-10R
Angola, IN
