Where can I find 7mm pilot and stones for this?
  • tybolt99
  • tybolt99's Avatar Topic Author
  • From where KZs came
Re: Where can I find 7mm pilot and stones for this?
14 Nov 2012 00:43
#558272
Thank you, Larry.
I will get face right. play with it with some old valves.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
  • LarryC
  • LarryC's Avatar
14 Nov 2012 09:05
#558294
tybolt99 wrote: Thank you, Larry.
Take as little as you need to get a straight, clean face. Watch you don't get the margin knife edged.
Larry C.
  • tybolt99
17 Nov 2012 09:13
#558763
Thanks, I will. Without knowing, I probably would have it edged. :laugh:
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
  • LarryC
  • LarryC's Avatar
18 Nov 2012 22:47
#559050
This is what I use to setup installed heights. The short block is 1.475". Use that for a quick reference with vernier calipers for plus / minus.
The dial indicator is for fine tuning to get things exactly where you want them.
Attachment installtools.jpg not found
Larry C.
  • tybolt99
19 Nov 2012 00:11
#559068
I have one of this.
The dial indicator set up is nice.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
  • LarryC
  • LarryC's Avatar
19 Nov 2012 19:59
#559193
2 more I use regularly that might help you at some point.
Valve measuring & trimmed calipers to measure port short side height.'
Attachment tools.jpg not found
Larry C.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
19 Nov 2012 20:25
#559197
Okay, I've been watching this and now I got a question. When your sinking the valves to get clearence for big cams. Which valve do you sink the most?
Not picking your brain to do it, just to understand it and why.
Les
  • LarryC
  • LarryC's Avatar
20 Nov 2012 09:30
#559271
les holt wrote: Okay, I've been watching this and now I got a question. When your sinking the valves to get clearence for big cams. Which valve do you sink the most?
Les
You have to take all the parts into consideration.
Depends on the cams, the thickness of the buckets, the retainer cup depth and the valves Les.
with over size valves, both sides get sunk. Sometimes a lot. Especially if the cams have a ton of TDC overlap lift.
On moderate cams, say K410, it's not as tight using say a 38mm GPz 11 or Suzuki GS1000 intake valve as it would be with an old 3X Andrews or PSP3x.
Always use a small base circle cam with larger valves. I like J, GPz and Suzuki GS Intake valves because they are shorter by about .050"
Larry C.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
25 Nov 2012 11:16
#559976
Reason I asked is from my past experience sinking the valves can kill flow. The exhaust doesn't seem to hurt performance as much as the intake and wondered about sinking the exhaust the most.
Les
  • LarryC
  • LarryC's Avatar
26 Nov 2012 12:43
#560124
les holt wrote: Reason I asked is from my past experience sinking the valves can kill flow. The exhaust doesn't seem to hurt performance as much as the intake and wondered about sinking the exhaust the most.
Les
Sure it can happen. But the old saying "never sink a valve" has to be taken with a grain of salt because it's not a blanket statement that covers every situation. Not all motors respond the same with the same intake vs exhaust flow ration either. There are so many overlapping events going on inside a running cylinder that at any given point in the cycle, something is out of phase from optimum.
Larry C.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
26 Nov 2012 18:20
#560140
Kinda figured it was a give and take or more like a beg, borrow, steal situation. I understand the compromise. Thanks for the info.
Les
