Lisle Valve Keeper tool
- 750steve
14 Sep 2012 06:51
Has anyone here got & used one? I see they are sold
SEPERATELY
or in a
PAIR
. Which one is applicable to our motorcycle application?
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- elfmagic17
Re: Lisle Valve Keeper tool
15 Sep 2012 00:05
Yes I bought the same tool from Matco through our dealer as the pair. The one for the smaller valves is the one you will need. It's for like 7mm stems. Worked great with the head already off but should work good with some air in the cylinders with the head on.
Kenny Hicks
74 Honda CB550
74 Honda CB550
- elfmagic17
15 Sep 2012 00:08
Also I paid over $90 for mine. And invest in a good heavy rubber or dead blow mallet to hit it with it's really hard to just push it with your hands.
Kenny Hicks
74 Honda CB550
74 Honda CB550
- LarryC
20 Sep 2012 11:03
For the handful of fasteners that need removing and the cost of the gaskets, there's rarely a good reason to not pull the head if the valve keepers need to be removed.
If it's to replace seals, chances are the valves are all coked up on the port side and need to be removed and cleaned anyway.
If it's for a race bike that valve springs are a worry....that's a bit different.
Larry C.
- OldSchoolZ
23 Sep 2012 02:16 - 23 Sep 2012 02:18
magnet to remove and small needle nose and screw driver to install. Im faster like that, than the guy with the 90 dollar tool. :laugh:
Also install all pistons into cylinders with my fingers and rock pistons with tiny screw driver handle.
Did I mention Im oldschool? :woohoo:
Remember, don't work on your bike so much you never ride it.
Last edit: 23 Sep 2012 02:18 by OldSchoolZ.
