Portable / Handheld Tachometer
- Archiddeon
24 Jul 2012 02:05
Does any have a portable tachometer that they have used and would recommend? I am looking for something that is sufficiently accurate (the manual says +/- 25 rpm) and yet affordable (have seen some upwards of $300). Some sort of inductive tach would probably be best.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
1983 GPz 550
1985 Honda CH150 Scooter
1995 Suzuki GS500E
1995 Suzuki GS500E
- wireman
Re: Portable / Handheld Tachometer
24 Jul 2012 02:28
Dont some timing lights have that feature?
- Motor Head
24 Jul 2012 10:13wireman wrote: Dont some timing lights have that feature?
Yes they do.
Also a good DVOM will have an Inductive Pick-up for a Tach signal.
24 Jul 2012 10:23
Take a look at dwell meters. Pretty much all of them have built in tachometers. Ed
- loudhvx
24 Jul 2012 12:38 - 24 Jul 2012 12:41
This is the one I use. It's pretty cheap. I think you can get them on ebay for $25 somtimes. The tach is very precise for doing mixture tuning.
www.actron.com/product_detail.php?pid=16160
It is sold under the Sunpro name, and the Craftsman name, as well.
Like any dwell/tach gauge designed for classic cars, you have to multiply the gauge numbers to get the true reading. For instance, on this meter you multiply the gauge reading by 4 to get the true RPM, and 8 to get the true dwell angle.
You connect it to one of the coil leads. I leave a short wire on the coil that I can access from under the tank without removing the tank.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 24 Jul 2012 12:41 by loudhvx.
- Archiddeon
01 Aug 2012 16:19
Thanks all!
I picked up an Actron unit on ebay for $10
1983 GPz 550
1995 Suzuki GS500E
1995 Suzuki GS500E
