Ghetto piston ring compressors
  • jason8887
  • jason8887's Avatar Topic Author
01 Jul 2012 03:39
#532979
So, I'm sure other guys have used this technique, but I thought it might be fun to put something together with some pics. So, here it goes
Step one: Get a good energy drink in you. You need to be focused for this!
Attachment IMG_5198.JPG not found
Step two: grab that old license plate hanging on your wall. You know, the one that your wife/girlfriend/husband/boyfriend gives you crap about everytime they walk in your shop: "Why do you keep this junk?!" Cut strips out that are as wide as a hose clamp that will fit around your piston and rings. Trim the length to allow the strip to almost touch when wrapped around the piston
Attachment IMG_5199.JPG not found
Attachment IMG_5201.JPG not found
Step three: Don't forget to debur the edges! The last thing you want is a little sliver of aluminum floating around in your bottom end
Step four: Get some more energy
Step 5: Roll the strip into your hose clamp, then place it on your piston and compress the rings. Note that you may want to do this step after putting your pistons on your bike
Attachment IMG_5204.JPG not found
Step 6: Start sliding your block over the pistons. If the ring compressors are not sliding easily then you should loosen them up a bit
Attachment IMG_5210.JPG not found
Step 7: When you have slid your block down as far as possible, remove the clamps and strips. IMPORTANT: slip a piece of wire or screwdriver under the piston to keep the strip of license plate from falling down into the crank case!
Attachment IMG_5211.JPG not found
Step 8: You will no doubt be completely pumped at how easily this went together, so you had better take something to calm you down
