What's this called?
- SPARKY47
- 1980 KZ500 B2
What's this called?
26 Apr 2012 18:10 - 26 Apr 2012 18:16
Hi Guys.I'm trying to get a magnet off the end of a 550 crank and need to order one of the items in the photo below.Does anyone know what the correct name for one of these is please?And if possible the correct size to order.(the one pictured is too large).
Many thanks in advance.The part on the right screws into the one on the left.
1980 KZ500 B2
Last edit: 26 Apr 2012 18:16 by SPARKY47.
- rstnick
Re: What's this called?
26 Apr 2012 18:18
Looks like some sort of puller.
To remove the flywheel, you may need a flywheel puller.
On the 650, you can remove the center nut, then use the rear axle threaded into the flywheel snug, then tap tap tap on the end of the axle and the flwheel should come off.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: SPARKY47
- SPARKY47
- 1980 KZ500 B2
26 Apr 2012 18:58
Thanks rstnick.The larger part screws into the centre of the magnet then the other part screws into the crankshaft through the larger one,Its designed to pull the magnet off the crankshaft.I just don't know what its called.
1980 KZ500 B2
26 Apr 2012 19:16
It's called a flywheel puller. Here's an example although not necessarily the size you need:
www.amazon.com/gp/product/B005CWA1I2/ref...00Y29BG14H6G55WPVNWJ
- roy-b-boy-b
26 Apr 2012 19:51
As was suggested there is usally a bolt on the bike you can pull the flywheel with. Most are the rear axle. Just use something to hold your rear wheel while you do this.
Some bikes use the large triple tree bolt.
This will save you s lot of money. Roy
26 Apr 2012 20:06SPARKY47 wrote: Hi Guys.I'm trying to get a magnet off the end of a 550 crank and need to order one of the items in the photo below.Does anyone know what the correct name for one of these is please?And if possible the correct size to order.(the one pictured is too large).
Perhaps of interest ---
www.z1enterprises.com/detail.aspx?ID=2176
www.z1enterprises.com/detail.aspx?ID=2163
- SPARKY47
- 1980 KZ500 B2
26 Apr 2012 22:46 - 26 Apr 2012 22:47
Thanks Ed.
Thanks Patton.Clearer now.
Thanks Roy.The crank is sitting on my bench.Do I just need to stop the crank turning while I thread a bolt in,then tap,turn,tap etc?
1980 KZ500 B2
Last edit: 26 Apr 2012 22:47 by SPARKY47. Reason: I'm old.
