anyone ever use a harbor freight torque wrench
- ramtough_63
05 Feb 2012 11:52
It's time to start torquing all my swingarm parts. I am nearly broke so I can go buy a cheap torque wrench or borrow a good one. sometime next week
Some tools I dont mind buying on the cheap a torque wrench isn't really one of em.
I lost all of my tools several years ago in a messy divorce and until this build havent really accumulated any of them back.
If anyone has used one with I'd appreciate some input.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Motor Head
Re: anyone ever use a harbor freight torque wrench
05 Feb 2012 12:10
Yes I have, and I'm sure many others have too. Is it perfect in its calibration? No most likely not, but its probably within 5%. So the biggest benefit of using a torque wrench is still the same, all bolts torqued evenly, and not over torqued. It would be much better than no torque wrench.
- ramtough_63
05 Feb 2012 12:39
Thanks Motor head I really need one and I was thinking if I wait to buy an expensive one I may never buy it. To easy to get a bolt tight and forget about it.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- jonnybravo
- Banned
06 Feb 2012 15:44
I got 2, I checked one of them and it was off, how I did it was clamped it in a vise and took a 20 llb weight and attached it to the end, it turned out being 3 lbs off, but knowing that i could still use it just adjusting with a little math
- Mcdroid
- Gone Kwackers
06 Feb 2012 16:44 - 06 Feb 2012 16:45
I have two Harbor Freight wrenches also, one in inch/lbs and the other in foot/lbs. I have had both calibrated against expensive torque wrenches that were correct and mine were very close to the expensive wrenches...enough so that I didn't make any changes. Both wrenches are the 'clicker' type and when not in use, I keep them completely turned out.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 06 Feb 2012 16:45 by Mcdroid. Reason: clarity
- david1050
09 Feb 2012 15:55
I have one and like others have said it's not perfect but close. I would buy one again.
David
2009 Vulcan 900 Custom
1975 Z1B 900 Mod/Resto project (91 KZ1000P forks and wheels)
1976 KZ900 Cafe bought to flip
1982 KZ750R1/GPZ750 project (95 ZX7 forks, 03 ZX636 swingarm)
- ramtough_63
09 Feb 2012 17:04
I have always went with the theory "fully seated, not stripped" as my reference but really think torquing to spec's will help ease my mind. especially the way this KZ vibrates. lost the nut off my brake pedal within 100 miles of the maiden voyage lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- DoubleDub
09 Feb 2012 18:05
Locking nuts are your friend...
- ramtough_63
09 Feb 2012 18:28
and locktite lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Murphyau
Author
12 Feb 2012 18:42jonnybravo wrote: <snip> I did it was clamped it in a vice and took a 20 lb weight and attached it to the end, it turned out being 3 lbs off <snip>
I did the same, but I checked it with a number of different weights (20, 40, 60, lbs).
From my experience, and what I have read elsewhere on the web, the "cheaper" clicker type torque wrench are reasonably accurate in the middle of their range, but can be way off at either end of their range, so I try and stay in the middle 80% of the range.
My 1/2" drive torque wrench is 10 ft/lbs to 150 ft/lbs, then I try and use it in the 30 ft/lb to 120 ft/lb range.
12 Feb 2012 19:30Murphyau wrote:jonnybravo wrote: <snip> I did it was clamped it in a vice and took a 20 lb weight and attached it to the end, it turned out being 3 lbs off <snip>
Good point! Especially on the low end of the scale; this is true of even the finest torque wrenches. Here's an excerpt from the CDI torque wrench site (CDI is a Snap-On company that manufactures torque wrenches):
Attachment CDIClip.jpg not found
- saltfuture
02 Mar 2012 13:47
Best $10 torque wrench I ever bought.
"The idea that God is an oversized white male with a flowing beard, who sits in the sky and tallies the fall of every sparrow is ludicrous. But if by 'God,' one means the set of physical laws that govern the universe, then clearly there is such a God. This God is emotionally unsatisfying... it does...
