HF Comp Tester Reads Low
  • Motor Head
  • Motor Head's Avatar Topic Author
06 Oct 2011 00:02
#481615
I bought one of these for the adapter fitting, tried it and it read about 20PSI lower than my trusted gauge. Be careful If you buy one, then decide your Motor has Low Compression! get another know good gauge to verify the reading.
www.harborfreight.com/compression-test-kit-66216.html
  • Fritula
  • Fritula's Avatar
  • holly land garage
Re: HF Comp Tester Reads Low
24 Dec 2011 16:02
#494551
nothing is made in USA anymore. :(
  • loudhvx
  • loudhvx's Avatar
24 Dec 2011 16:23
#494554
Do the brass spark-plug adapters each have a check valve in them? If not, there goes the compression.
I've seen other cheap ones without check valves. They always read very low. It's almost as if the person designing it had no idea what they were for or how they should work. :huh:
  • DoubleDub
  • DoubleDub's Avatar
24 Dec 2011 17:23
#494561
I guess I don't understand - what does the check valve do? Obviously, I don't design these :laugh:
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
24 Dec 2011 23:55
#494586
DoubleDub wrote: I guess I don't understand - what does the check valve do? Obviously, I don't design these :laugh:
I would think it keeps the pressure from bleeding back into the cylinder when you stop cranking it over.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • steell
  • steell's Avatar
25 Dec 2011 01:30
#494599
Without a check valve you're basically making the combustion chamber larger, thus lowering compression. With a check valve you're making the chamber larger until the pressures equalize at max psi, at which point you're not pushing any more air into the gauge.
The following user(s) said Thank You: DoubleDub
