if your clutch cable ever snaps...
- djturnz
Re: if your clutch cable ever snaps...
20 Jul 2013 20:35
So you just hose clamp the cable to the lever? What's the house for then?
1982 KZ750 (4) LTD
20 Jul 2013 22:22No hose. Just a clamp.djturnz wrote: So you just hose clamp the cable to the lever? What's the house for then?
What size clamp?
A little clamp.
How little?
The size that would fit a small hose.
A small hose such as fuel line?
Yes, like a clamp used to tighten the end of a fuel line.
What's a clamp like that called?
A hose clamp.
Or maybe a little hose clamp?
Just say a small hose clamp.
But which is small, the hose or the clamp?
A small hose would need a small clamp to fit the small hose.
What about a little clamp to fit a small hose?
That would be okay.
Or what about a small clamp to fit a little hose?
That's okay, too.
Or a little clamp that fits a little hose?
Sure.
So, is it a small hose clamp? Or a small hose clamp?
Could say small hose hose clamp.
Could I use the hose clamp off the petcock?
Maybe, if it didn't start leaking gasoline.
If it's dark, how would I know?
[No comment.]
The following user(s) said Thank You: steell
- kzz1king
20 Jul 2013 23:22
The soldering trick ALMOST got me home once. Running lights and clutch less shifting got me the rest of the way!
Wayne
Wayne
Home built KZ1000 turbo setup
- Philip Meaney
12 Nov 2013 15:57
I got home using a pair of visegrips on the clutch actuator on my 750 Turbo once. Made for an interesting ride.......
80 750 H1
85 750 Turbo
84 GPz 750
85 750 Turbo
84 GPz 750
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
12 Nov 2013 18:44
flanderscompany.com/About.html
Try this place you can make your own our make a spare just incase.
