vaccuum gauge air valve
- apbling
03 Jun 2011 16:49
So, I have a set of vaccuum gauges that use those little plastic valves to dampen the needle... anyway, my buddy borrowed them and removed the valves...and now they are mia. Where the heck could I find some more? Think an aquarium place would have some? They remind me of something that you would use for a fish tank...
- TeK9iNe
- What did you do!?!
Re: vaccuum gauge air valve
03 Jun 2011 19:51
The dampers are just a plug of anything - plastic, wood, etc. with a 1 mm hole drilled throught the center.
You can even just use a locking clamp mechanism in the mean time and slowly open it till you get response. Basically it just makes a very small opening in the line to reduce reactions in the guage to the pulses. Should be as close to the engine as possible.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
