factory shop manual
Last edit: 11 Feb 2013 18:12 by martin_csr.
Re: factory shop manual
09 Mar 2011 18:06 - 09 Mar 2011 18:08
PLUMMEN wrote:
Because the adjustments to these highly complex systems are crucial to protecting the global ice caps, the adjustment mechanisms are sealed with 2.5kg of JBWeld. Only qualified personnel should attempt to remove the sealant. If you are qualified, be sure to wear the appropriate HASMAT suit and be certain to dispose of the residue according to CARB and EPA guidelines.
The only owner-serviceable part of the emissions system is the reed-induction piston redacter. Once every 31,437.3 km or four days, whichever comes first, replace the 17.803 litres of fluid and the fluid filter. Use only genuwine WD39 and a made-for-Kawasaki Fram filter.
However, if the motorcylce diplaces less than 1000cc or has fewer than four cylinders, toss a lighted match in the fuel tank and run like you are chasing naked blondes.
To protect the enviroment in which we al live,Kawasaki has incorporated two emission control systems in compliance with the applicable regulations of United States Enviromental Protection Agency.
Last edit: 09 Mar 2011 18:08 by TexasKZ.
- Old Man Rock
09 Mar 2011 18:15
How about a free Kawi OEM Manual 1981-1983 KZ1000/1100...
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
09 Mar 2011 18:16
Not only is my manual missing the emission control stuff, some dufus tore out the chase picture. :pinch:
- djesurun1
13 Oct 2011 13:50
Table of Contents
Ch. 1................................................................................. General information
Ch. 2.................................................................................Scheduled Maintenance
Ch. 3.................................................................................Engine
Ch. 4.................................................................................Chassis
Ch. 5.................................................................................Electrical
ijojfdsfa;sdofids v0vaca
cvacvavacv
ZZZzzzzzzz...................... Huh? Where am I ???
cvacvavacv
Waiting to Ride a 98' KZ1000-P
Starters out of commission...stuck on four wheels at the moment
My $700 project bike is on its way!
- jonnybravo
- Banned
16 Oct 2011 06:55 - 16 Oct 2011 06:56ur on a dead thread, Ozzy :woohoo:djesurun1 wrote: Table of Contents
cvacvavacv
" Of all the things I miss I miss my mind the most.
-Ozzy "
Last edit: 16 Oct 2011 06:56 by jonnybravo.
- djesurun1
21 Oct 2011 23:56
looks like its getting a revival though!
- SPARKY47
- 1980 KZ500 B2
24 Oct 2011 19:09 - 10 Nov 2011 10:47
deleted
1980 KZ500 B2
Last edit: 10 Nov 2011 10:47 by SPARKY47. Reason: old and deluded
