OEM TOOLS?
- Grinder
- Summerville SC long time KZ owner Short time membe
OEM TOOLS?
11 Feb 2011 06:56
Is there a list of oem tools the came with KZ1000?
i have a tool pouch that i have put together!
8,9,10,12mm open and boxed end
spark plug socket
screw drivers
plyers
adjustable wrench
sand paper
wireing diagram
replacement fuses
spark plug socket
screw drivers
plyers
adjustable wrench
sand paper
wireing diagram
replacement fuses
- Mcdroid
- Gone Kwackers
Re: OEM TOOLS?
11 Feb 2011 07:12
Yes, I believe there is, but they are not listed on the Kawasaki website diagrams. I seem to recall the owners tools being listed on the microfiche, which I have at home. If no one posts an answer to your question today, I'll look tonight at the microfiche.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- hocbj23
Re: OEM TOOLS?
11 Feb 2011 10:32
I have a couple of what I believe are complete tool pouches for the KZ.Contents are as follows:24,22,19 mm box ends,17/14,13/12and 10mm open ends, black screwdriver handle with phillips and flat tip inserts,R20.5 spanner for shock adjustment,extension handle for the box ends,pliers,plug wrench with handle.Earlier models had gap gauge for plugs/points and I have one of those as well.Spare fuses are carried in the fuse box cover.hope this helps.bj
- TeK9iNe
- What did you do!?!
Re: OEM TOOLS?
11 Feb 2011 10:45 - 11 Feb 2011 10:46Pretty self explanetary form the image.
9 is a feeler gauge
16 is a plug wrench
18 is some gasket sealer
The whole origional kit can be purchased for around $80
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 11 Feb 2011 10:46 by TeK9iNe.
- gane
Re: OEM TOOLS?
11 Feb 2011 15:43
This will sound retarded, But.I own an "original" tool kit, & owners manual. Neither travels w/me. I do however have a "Dick & Jane" 3 page fold 0ut wiring diagram,(which resides in the tail section w/ reg/ins.forms) & since I run "Pods" a velcro/nylon "tool pouch" which hangs from the frame rail inside the r/h side cover. It includes 8-17mm Craftman wrenches,4-8mm allen wrenches, an axle spanner & extension, a plug socket,a "stock" screwdriver handle w/straight & phillips bit, a "home made" test light, safty wire, elect tape(wound around extension) spare fuses, a set of plugs a couple 1157/1156 bulbs. a stock points plate & advance unit, a small crescent wrench, a small pair of pliers & a joint. The quality of "stock" tool kit componants were POOR at best. DO YOUR' WORK AT HOME... Yes, emergencys will arise on the road, cover the consigancys you can without back-up & ride close to home for the first couple hunnert miles. Never plan on a extended outing without a pre-ride. luck g
[img][/img] 1977 KZ1000A1
- Grinder
Re: OEM TOOLS?
11 Feb 2011 19:35 - 11 Feb 2011 19:35
all real good advice. kinda the way i was leaning , was to put together something of quality from my coloction of tools and get a axel wrench, shock spanner, plug socket to carry in a leather pouch i have. and i do know this bike is 30+ year old machine. i am leaving stock airbox and dont have a lot of room.
My last bike had room for 20 lbs of stuff!
thx again
thx again
Last edit: 11 Feb 2011 19:35 by Grinder.
Re: OEM TOOLS?
11 Feb 2011 19:38
Enjoy also carrying a short length of hose that fits snugly over a spark plug to remove while hot without burning fingers.
- Michelle4Edwards
Re: OEM TOOLS?
21 May 2011 02:42gane wrote: This will sound retarded, But.I own an "original" tool kit, & owners manual. Neither travels w/me. I do however have a "Dick & Jane" 3 page fold 0ut wiring diagram,(which resides in the tail section w/ reg/ins.forms) & since I run "Pods" a velcro/nylon "tool pouch" which hangs from the frame rail inside the r/h side cover. It includes 8-17mm Craftman wrenches,4-8mm allen wrenches, an axle spanner & extension, a plug socket,a "stock" screwdriver handle w/straight & phillips bit, a "home made" test light, safty wire, elect tape(wound around extension) spare fuses, a set of plugs a couple 1157/1156 bulbs. a stock points plate & advance unit, a small crescent wrench, a small pair of pliers & a joint. The quality of "stock" tool kit componants were POOR at best. DO YOUR' WORK AT HOME... Yes, emergencys will arise on the road, cover the consigancys you can without back-up & ride close to home for the first couple hunnert miles. Never plan on a extended outing without a pre-ride. luck g
Its good variety and nice pic which is in black and white.
- dshelly
Re: OEM TOOLS?
21 May 2011 09:52
with all this talk about tool pouches I have a question. So on the Kz1000's where was the tool kit kept on the bike? in the tail? in the tray? I know my 900 ltd has a specific tool box, but I don't see one on my 1000.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- grumpy56
Re: OEM TOOLS?
21 May 2011 12:14
On the 1982 J2 it is kept under the seat next to the battery. The tail section is for "owner's papers" (as i read or saw some where).
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
