Index rod
  • gane
  • gane's Avatar Topic Author
Index rod
19 Dec 2010 14:07
#417753
Gents, I've 3 roller bearing cranks which I've aquired over the years, and have no idea of their "True". I would like to purchase a rod (if cheap enough) to "rough check" rod heights. Does anyone have a suggestion or 2 where I might source such a piece of stock ?
[img][/img] 1977 KZ1000A1
  • larrycavan
  • larrycavan's Avatar
Re: Index rod
19 Dec 2010 15:08
#417770
Courtesy of wiredgeorge:
The rod in question is a 17mm drill blank - a nice, straight rod... If you can fit the rod in the 17mm holes in all four rods where the piston pins normally go, the crank will be a straight one. The holes are VERY tight and you may have to grease the rod up a tad. I think you can get the rods from McMaster-Carr or whatever that tool place is called. I think that is where I got mine. I also think that scientific folks call this "indexing the crank" but I might be mixed up on that fact...
See:
kzrider.com/index.php?option=com_kunena&...d=2&id=155915#155959
Good Fortune! :)
  • rslingshot
  • rslingshot's Avatar
Re: Index rod
19 Dec 2010 17:09
#417802
Ya patton is right, I use a 17mm polished drill rod that I got from msc industrial but I am sure you can buy them at mcmaster carr or grainger. Thats what I use when I weld up cranks.
  • larrycavan
  • kz1k
  • kz1k's Avatar
  • You Cant Fix Stupid!
Re: Index rod
20 Dec 2010 02:12
#417851
does anyone have a link to how to true your crank and where to weld it?
1978 KZ1000A2
  • gane
Re: Index rod
20 Dec 2010 17:44
#417961
My thanks to all.. At 25 bucks & shipping Travers is my opt. and reasonable to me despite the fact that I don't feel myself competent to push around a 4 cyl crank. (Falicon & Vance & Hines have inspected/trued welded all my roller crank projects in the past & I'm happy.) again thanks g
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: Index rod
20 Dec 2010 17:54
#417965
I don't think this is something you want to do in the garage unless you have the proper tooling to do so. Your crank will pull when you weld it, just like everything else does. As for where to do it that would be on both ends of every pin in the counterweights not an easy task with the crank assembled I imagine.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
