Not a tool but stiil good Idea .
- JMKZHI
Re: Not a tool but stiil good Idea .
26 Nov 2010 07:15
Tomato juice, vinegar, orange juice, or lemon juice could be used (ph range ~ 4-2).
Or you could probably use chrome polish which usually has an acid in it, but I'd test a hidden area first... the combination might be a tad aggressive, causing a dull spot.
I've used brass wool occasionally on neglected parts.
The Mohs scale kinda explains why aluminum doesn't scratch the chrome.
Aluminum's hardness number on the scale is ~2.5.
Iron is 4, but rust is probably weaker.
Chromium is 8.5.
Diamond is 10.
Which got me to wondering if there is something else out there that would be good to use instead of the aluminum. The only thing that comes to mind is gold leaf, but that would be a tad expensive.
Chromium is 8.5.
Diamond is 10.
26 Nov 2010 07:50 - 26 Nov 2010 07:52
Last edit: 26 Nov 2010 07:52 by Patton.
