Engine stand or cart? for KZ1000
- PLUMMEN
Re: Engine stand or cart? for KZ1000
15 Sep 2010 17:48
nothing wrong with dumpster diving,just make sure garbage man sees ya going in! :woohoo:
- Nelson
15 Sep 2010 18:01
JakeB wrote:
I like the 1 bolt and flip it over idea. I made a rolling wooden table, I might add a steel bracket similar to yours.
It's just one bolt through the lower rear mount and rests on the support in the front. It could be flipped up, but I didn't think the cart was sturdy enough to do it.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- Afrosemite
26 Oct 2010 19:19
Anybody use one of these?
www.harborfreight.com/1000-lb-capacity-engine-stand-32916.html
I like the price
I like the price
\'78 Kz650d sr
- Nelson
26 Oct 2010 20:53
I think somebody mentioned that earlier. seems to me you'd have to do so much fabbing to it that you might as well build something from scratch.
- Afrosemite
26 Oct 2010 21:08
Doesn't seem like too much fabbing. Would it have to be more than a two real strong L-brackets?
Some of the pictures here look plausible:
www.landracing.com/forum/index.php?topic=5319.0
\'78 Kz650d sr
- Becker
- The Doctor Will Rise Again
26 Oct 2010 21:29
All you would have to do is make a head that could mount to the engine and also go into the pipe that holds it in the stand. You could still use it for alot of other stuff too. I made one from scratch that wasn't that big and it cast me about 32 dollars. It also doesn't have wheels. I'll try to find a picture of it.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- hal0tw0
27 Oct 2010 04:36
Ive had the HF stand. It worked well and deff was a good price. I rebuilt a chevy 350 and a toyota 22r on it just fine. But those were car engines, you would have to make brackets im sure for a motorcycle engine.
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- Old Man Rock
27 Oct 2010 05:22
Downfall of any stand is you still have to LIFT that heavy pig of a motor up into it for bolting on.... :pinch:
Need one that while laying flat surface aka Bench top, curved arms slide into engine mounting holes, then bolt on, then pushing/rotation of the curved arms down for raising engine up....
Think rear wheel stands for raise concept..... Once up, the stand is also design for locking into position 90 & 180 degree rotations.... Now you're talking...
Hmmm, me wonder....
Hmmm, me wonder....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- alwaysbroke
28 Apr 2011 13:06
Old Man Rock, awesome idea! Have you fabed one yet? Something like that would be such a back saver.
I modified this HF wagon to hand-pull a 14 foot sail boat too/from the water and campsite. 2 people can carry this fiberglass boat but its difficult as there is really no where to hold onto. I modified this wagon so that its small enough to fit in the back of my truck but will stretch out in the center to about 11 feet to accommodate the boat. I've loaded it up with 6 big ice-chests as well at a school outing. Seems to be pretty stout (.....until it breaks)
Anyhow, my Z1B has no center stand so I tore my bike down while the frame was resting on 4 small HF car stands. I really wanted to clean the motor/frame outside but didn't want to put the anything back on. Figured the wagon could handle it's weight so I used my floor jack to get it high enough and wooden 4x4 blocks as needed. Its easy enough to get onto my 4x8 trailer (once again a FH item...:S )and have carted it to the carwash / welding shop. I just had to be certain that everything was braced and strapped down tight.
One of my favorite sayings...work smarter not harder.
Attachment frameonstands.jpg not found
Attachment wagon.jpg not found
'75 Z1900
'74 CB750
'74 CB750
- Injected
29 Apr 2011 22:15 - 21 May 2011 01:26
I finaly built one for use on 650 motors... about $7 worth of tube steel and brazed it together in about 10 minutes. Bolts together with 3/8" threaded rod.
It's not fancy but gets the job done.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 21 May 2011 01:26 by Injected.
- wireman
30 Apr 2011 00:23
i really need to build some of those!
