Gas Supply Container
- ed spangler
- Tennessee Z
11 Jul 2010 08:07 - 19 Aug 2010 09:47
Good Morning
I have an old IV stand I use to hang tools when I am working on my Z1-B and to hang the 4 gauge set to calibrate carbs etc. I am trying to come up with something to hang from the old IV stand that will hold an adequate gas supply to feed the bik,for use when the gas tank is off the bike for ease of tuning,or other work. Anyone using something like this that is either easy to fabricate or inexpensive to buy.??
The old IV stand is very convienent!!
Update:08/19/2010
Bought a Motion pro Plastic Gas Container from Z1E, Think I will like it!!
Thanks!!
Update:08/19/2010
Thanks!!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Last edit: 19 Aug 2010 09:47 by ed spangler. Reason: Update 08/19/2010
- PLUMMEN
Re: Gas Supply Container
11 Jul 2010 08:27
ive had good luck with plastic lawn mower gas tanks with in line shut off valve
- mark1122
- Keep twisting it
11 Jul 2010 08:28 - 11 Jul 2010 09:51
PLUMMEN wrote:
x2
x2
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 11 Jul 2010 09:51 by mark1122.
- JMKZHI
11 Jul 2010 09:39
Not sure if it's inexpensive, but Z1Enterprises.com sells an auxiliary fuel supply that would work perfectly w your IV stand.
I have an old lawnmower tank that I got from the corner mower shop. It's a heavy duty plastic & has a nipple molded into it for attaching the fuel line. I've attached it to the bike for syncing the carbs & then going for a test ride.
- blipco
- 2002 KZ1000P
08 Aug 2010 19:35
From your local auto supply. Less than 9 bucks. I use a windshield washer fluid reservoir. Has a pair of tabs for mounting. I squeeze the hose with a pair of hose crimp pliers to shut off the gas.
- Motor Head
08 Aug 2010 19:47
I just use the stock gas tank, put it up on my tool cart with a towel under so it doesn't scratch. then hook up with a piece of clear tube and a in line filter. Pinch or block any petcock vacuum hose. One thing is you tune on the same gas you ride with.
- trianglelaguna
08 Aug 2010 22:22
i was eyeing an extra xt 550 thumper tank in my garage with bad intent....
Motor Head wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- mountnman
12 Aug 2010 12:34
not sure the price, but if your looking for something that would fold flat or roll up.... you can find "portable showers" at most camping supply shops including walmart- large hangable plastic bag with a valve and a shower head on a tube-- would think this would convert easily
- stonemaster
12 Aug 2010 14:25
trianglelaguna wrote:
you go Jethro
Motor Head wrote:I just use the stock gas tank, put it up on my tool cart with a towel under so it doesn't scratch. then hook up with a piece of clear tube and a in line filter. Pinch or block any petcock vacuum hose. One thing is you tune on the same gas you ride with.
you go Jethro
12 Aug 2010 14:56 - 12 Aug 2010 15:00
Gasoline dissolves many types of plastics, some more quickly than others.
Would be very careful about using any plastic container not positively known to be absolutely gasoline proof. And certainly not store any gasoline in it.
That's why it's best imo to use an old lawn mower gas tank, or a gas tank from some other source, as the temporary supply tank.
Thanks to ed spangler, above, and to Jeff at Z1E for suggesting usefulness of a hospital style I.V. stand to support the temporary tank.
Last edit: 12 Aug 2010 15:00 by Patton.
- turbo nate
19 Aug 2010 14:55
i converted a rabbit water bottle, but the gas swelled the screw on top and it popped off with nearly catastrophic results. as stated above, gas will dissolve many types of plastics, but sometimes just swells and softens it. you should let it sit overnight full of fuel to make sure it will be ok since it took over an hour to swell and pop off almost burning my street fighter to the ground
