Small Piston Ring Compressor
- cruspeed
14 Apr 2010 10:49
Get some metal pallet banding and run a wire wheel over it to get it smooth and clean and coat it with oil, use this against the piston. I also put a small bevel on each side to keep sharp edges away from scratching the piston. Bend it tight so there are no flat spots and clamp it on your piston rings with a zip tie. Place the zip tie end over the outer end of the banding so you can get it tight. When you have your piston in the block just cut the zip tie and your done.
78 KZ1000 project X 2
- rt green
- otakar
Re: Small Piston Ring Compressor
15 Apr 2010 14:12
That is absolutely brilliant.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
15 Apr 2010 16:39
outstanding...way to use the head for more than a hat-rack........
- timebomb33
15 Apr 2010 21:32
that is one of the best cheap or free ideas i have seen in along time nice job.
I THINK MY POWERBAND BROKE
- cruspeed
16 Apr 2010 11:39
you can use a large heater hose clamp instead of a zip tie if you wanted to be high speed!
If anyone needs some pieces of banding let me know!
