Getting the right welder
- Darkangel
20 Mar 2010 14:01
Ok I want to do a few mods on my bike, and I need to buy a welder. I've welded professionally before, but not on a motorcycle. I am guessing tig or mig would be the way to go...Any other suggestions?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- Old Man Rock
Re: Getting the right welder
20 Mar 2010 14:35 - 20 Mar 2010 14:37
TIG would be the way to go for clean welds alone.
Increased concentrated weld puddles plus different types of metal as well as metal gauge/thicknesses that you could go down to versus MIG speak for itself... i.e. stainless but the price in ARGON these days is rather pricy...
Not to mention most fair to good Heli-Arc welders are 220Vac then need the tig rig then throw in tungsten electrodes, rod wire, regulator etc... can get spendy real quick.
If 99% of the work is frame related and being mild "Carbon" steel so a MIG unit is more then enough... The unit I got came with a regulator for ARGON bottles where Stainless and Aluminum are possibilities/options.
All mods made to my frame I used a little ass 110Vac MIG welder, no probs...
Truly depends on what your planning on in your fabrication and what your willing to spend, not only to purchase but in continued use...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 20 Mar 2010 14:37 by Old Man Rock.
- Darkangel
20 Mar 2010 14:44
Well i plan doing some real light fab work on the rear end. I plan on moving the seat up at an angle, and fab'n up a shock mount. I was going to be cheap and get a CH welder, but i figured I would just get me a lincoln mig..140. I almost made the mistake of buying a flux only machine...then I realized that would be like using a stick on the frame..because flux is so hot.
- testarossa
20 Mar 2010 16:15
I've been using a Millermatic 135 on my bike, and it has worked out really well. That Lincoln 140 is very similar, and it ought to do the trick.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- rgoot01
20 Mar 2010 17:01
The 140 is good unit. Flux-core granted is hotter however that translates to increased penetration. I have used both solid and flux-core wire on my bike that I am building. The only real advantage to solid is that it creates less spatter. I personally don't care about the spatter cause I hit everyting lightly with a file to knock it off.
Rob
Salida,CO
Salida,CO
- KawiConvert
20 Mar 2010 17:31
Go with the millermatic. They are nice little welders. If you go for the Lincoln, check out Eastwood co's welders as they appear to be Lincolns in blue paint.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- porchev914
20 Mar 2010 17:34
I have had a Lincoln SP135 for the last 7 years and it has performed flawlessly. It is the predesessor to the 140. For light fab work on your frame it'll be more than enough. As OMR stated TIG would be awesome, but everyone I've seen is 2-3x the money and needs a 220v source. A 110v MIG box with a regulator and rheostaticaly controlled amperage would serve you well for your purpose.
FRANKEN Z!
- Darkangel
20 Mar 2010 20:03
I wish I could just use a stick welder...but I know I cant...But yeah I will be getting the Lincoln 140 here soon...i just saved up some money to get one of the big pipeline welders...it's older, and needs work...but it's for 500$
- PLUMMEN
20 Mar 2010 20:03
my hobart handler 175 came with the flux cored wire,but they also supply a regulator so all i had to do was add the bottle.
- testarossa
20 Mar 2010 20:18
Adding a bottle comes naturally for PLUMMEN! Adding the bottle can help in many situations.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
20 Mar 2010 20:26
propane,mapp gas ,nitrous,argon or beer.i aint scurred of none of em! :laugh:
- Kawickrice
20 Mar 2010 21:05
I paid $125.00 for my Lincoln mig at the pawnshop. I could not believe the price, not one scratch on it it was brand spanking new. Never got around to the adding the argon to it. Good little machine for my little projects.
My friend has the Hobart with the gas rig and he paid $100.00 for everthing.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
