Compression Tester Mod
- sabell
05 Mar 2010 07:32
I have a standard compression tester from HF. Has any one ever had any success modding one of these to perform a leakdown test?
'78 KZ1000A2
'79 650SR
'79 650SR
- mark1122
- Keep twisting it
Re: Compression Tester Mod
05 Mar 2010 14:10
U need 2 guages that will read 100 psi acuratly. join them together with small piping and T's. fill the pipe in between the 2 with epoxy , then drill a .040" hole in the epoxy.
now put an air fiting on 1 end and a spark plug fitting on the other end.
PRESTO.
PRESTO.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wes_scooter
07 Mar 2010 05:25
if your compression tester has a schrader valve in the bottom of the hose u need to remove it. i just use a 1/4 turn valve with a gauge mounted between the valve and the tester hose. set your regulator for what pressure you want. hook it up and let it presureize. close the valve and watch the gauge. works for me helps find bad vlaves. u can also hook the air hose right to the tester hose to provide constant air if its leaking bad and your trying to locate it. i've done this on automotive apps.
76' kz900
70' yamaha R5
2006 wr450f
70' yamaha R5
2006 wr450f
- Old Man Rock
07 Mar 2010 05:40
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- sabell
07 Mar 2010 07:06
wes_scooter wrote:
I'll give it a shot...thanks.
'78 KZ1000A2
'79 650SR
'79 650SR
- Becker
- The Doctor Will Rise Again
07 Mar 2010 16:04
And you can find a 20% off any purchase coupon in almost any motor/motorsports magazine. look in the back the have a full page add with differents specials for different magazines.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
