Fix for shrunken fuel pipes
- moneypit
07 Oct 2009 15:00
I used 3/8" heat shrink tubing and slide it over the end give it a little heat and done. they fit nice and snug that they are tough to turn when back in place.
2-76 kz900
St Paul MN
St Paul MN
- MFolks
Re: Fix for shrunken fuel pipes
07 Oct 2009 16:09
Be careful when buying heatshrink tubing, some have a meltable inner liner that will make the fix a real problem if you don't notice it.
- moneypit
- fixer5000
08 Oct 2009 09:46
another great idea!!!
1978 kz650b pretty much stock
massachusetts
massachusetts
- kawsakiman
08 Oct 2009 17:13
nice tip!
i would've never thought of that.
- chance
- Life long biker/
12 Oct 2009 17:03
Good deal.. I use teflon tape. You're a smart Guy..
- mtkawboy
16 Oct 2009 11:36
I dip the ends in Plasti-Dip one at a time once & let it dry hanging with the end pointed down, then do the other. Works for me, your results may vary. Plasti-Dip is what you dip plier handles in. I will try the shrink tubing, very clever. Ive used the teflon tape too.
Last edit: 01 Sep 2014 06:51 by Patton.
- kzdcw
- 77' KZ1000A
29 Aug 2014 22:42
Definitely Z1 Ent. has the Fuel T's and is the Best Option, but saving Money is always Good!
Moneypit, how is the shrink tubing holding up? I have some inexpensive 3/8" Harbor Freight heat shrink tubing, but don't what type of chemical resistive properties it may have?
77' KZ1000A
