The Cheapest Valve Shim Removal Tool
- Kawickrice
11 Sep 2009 13:35
I use plastic zip ties. Take a zip tie and fold in half and put a small bend at the end then pull out the spark plugs and put the zip tie down in the hole with the cam lobe down to open the valve. Now rotate the motor with a wrench and the zip tie will keep the valve down so you can remove the shim. It works like a charm and is very inexpensive and you can use two hands for shim removal.
I found this on the net so I can't take the credit
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- 9am53
- homebrew, and some bbq
Re: The Cheapest Valve Shim Removal Tool
14 Sep 2009 05:43
maybe I am paranoid from years of smoking wacky tabbacky, but would that not risk damaging the valve seating surface, or maybe bending a valve? maybe I am being dumb, but this method sounds too easy...
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- Kawickrice
15 Sep 2009 11:46
The most that could happen in my opinion is a little carbon gets dislodged and holds the valve open, thus giving a bad measurement. It is actually very simple and since you are turning the motor with a wrench it is a "Soft Stop". If it were to bend a valve the valve would have to shot beforehand. After using this method I will never use the wrench again. Just my opinion
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- MDawnz1
15 Sep 2009 22:21
Sweeeeeeeeet
I like this one ALOT.
Thanks
Thanks
1974 Z1a, still 903
- 9am53
16 Sep 2009 04:33
I am going to try it out in another month, I would rather buy a can of seafoam than a shim tool!
'84 GPz900r
'71 CB350
'71 CB350
- Kawickrice
22 Sep 2009 08:32
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- larrycavan
23 Sep 2009 19:05 - 23 Sep 2009 19:13
The proper tool is less than $10
www.motorcycletoolchest.com/Motion_Pro_0...g_Tool_p/08-0019.htm
Carbon between the seat and the valve seating surface makes an ugly mess of a valve job. I guess in dire straights, a guy could limp by with the zip tie....But the proper tool is so inexpensive that I just can't see risking screwing up a valve job for less than a $20 bill...
If you do choose the zip tie method, the first thing you better do is make sure the cam chain is adjusted [manual tensioner]. If you have slack in it and turn the motor over backwards, you could end up with your cam timing off.
JMO
Larry C
JMO
Larry C
Last edit: 23 Sep 2009 19:13 by larrycavan.
- Kawickrice
27 Sep 2009 12:28
I understand the proper tool is definitely the way to go, but this thread is about home made tools on the cheap. What is the bat shaped wing for? Also that tool almost looks to have a zip tie moulded in to the ball handle.
I try to always turn the crank forward on what ever it may be, just for that reason of possibly jumping teeth from reverse rotation.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
27 Sep 2009 15:10
Kawickrice wrote:
What is the bat shaped wing for? --- Same as special Kawasaki tool. Holds against lip of bucket to allow shim removal and replacement.
Imo, best to toss the ball-ended lever, and hand-rotate crank forward as described, using 17mm fake nut on crankshaft, whereby cam opens valve instead of using the lever.
Good Luck!
I understand the proper tool is definitely the way to go, but this thread is about home made tools on the cheap. What is the bat shaped wing for? Also that tool almost looks to have a zip tie moulded in to the ball handle.![]()
Good Luck!
