Valve Stem Retainer Removal Tool
  • roy-b-boy-b
  • roy-b-boy-b's Avatar Topic Author
01 Sep 2009 19:36
#318407
I had a brain storm one day and made this.
It's just a shim bucket with a hole in it. I had to torch the hole and clean it up with a die grinder.
I brazed the strap of metel on and drilled a indent to hold the end of a "c" clamp with the end removed. I use a nut glued to the other end of the "c" clamp for clearance.
