Budget Brake Bleeder
  • 650ed's Avatar Topic Author
31 Aug 2009 19:56 - 28 Jun 2012 09:12
#318093
Compliments of Shadow_Hare:
Be sure to keep reservoir replenished as this may work fast.
Step 1: Hook vacuum to jar:
Step 2: Attach small tube from jar to brake caliper bleed valve:
Turn on vacuum and open bleed valve. Keep reservoir replenished, and after fresh brake fluid starts flowing into jar close bleed valve, top off reservoir, and you're done.
Last edit: 28 Jun 2012 09:12 by 650ed.
Re: Budget Brake Bleeder
31 Aug 2009 19:58 - 28 Jun 2012 09:13
#318095
Last edit: 28 Jun 2012 09:13 by 650ed.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
02 Sep 2009 04:46
#318506
Far out!!!!:ohmy:
  • Martynbiker
  • Martynbiker's Avatar
  • 1993 KZ1000P
02 Dec 2009 18:16
#337153
Nice work, i find also if you go to a Vets or know someone with Horses ( or a farmer) get a BIG Syringe... one that holds about 100ml or more.. then use that to SUCK on the bleed nipple with a tube attached.
Works perfectly.
Sorry for the thread Hijack.
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
11 Aug 2011 00:52
#468317
I use a cheap rubber tennis ball size syringe with a short length of clear tube pressed onto the tip, then suck it full of fresh brake fluid, press out any air, press clear tube onto the loosened bleed nipple, and inject brake fluid until the fluid enters and partially fills the master cylinder reservoir.
Then bleed in the usual manner.
Good Fortune! :)
  • steell
  • steell's Avatar
11 Aug 2011 01:48
#468330
roy-b-boy-b wrote: Far out!!!!:ohmy:
Farm out !!!!!!!!! :P
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
11 Aug 2011 10:47 - 11 Aug 2011 10:48
#468364
Patton wrote: ....blah, blah, blah...bleed nipple....blah, blah, blah.....
:woohoo: :woohoo: :woohoo: :woohoo:
:whistle: :whistle: :woohoo:
Good Fortune! :)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
Last edit: 11 Aug 2011 10:48 by RetroRiceRocketRider.
