where to buy kZ650 hotter cams
- martijn
14 Dec 2006 00:39
I'm planning to make my 650 a little faster, Where can I buy suchs cams for a good price?? and what do you recommend for street use? will be used with 710 wiseco's
Thanks Martijn
Thanks Martijn
- Lorcan
- Speed Loony
Re: where to buy kZ650 hotter cams
14 Dec 2006 01:43
GPz750 cams are cheap and work well. You may need to swap the cam wheels over from hy-vo to roller chain.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- 77KZ650
14 Dec 2006 16:37
if you want to spend a lot and get better than the gpz cams, check out web cams or megacycle cams.
Scott
Scott
07 MDP Rookie of the Year
