kick starter shaft
- drahotus
kick starter shaft
23 Nov 2005 20:22
hi!
i'm going to split cases on my kz 1000 78 and while i will work on the motor....
i would like to know why some guys remove a kick starter shaft.i have seen many bikes many times without that.than they just put a plate from APE there.
is it because the weight? or they don't use it?
i'm just wonder.
thanks :S
i'm just wonder.
thanks :S
- wiredgeorge
Re: kick starter shaft
25 Nov 2005 06:59
Racers use a remote starter to spin the crank to start the engine and don't carry a starter. If you have ever picked up a kicker shaft you would know right away why that is left out when the cases are split... heavy and since it isn't used, it is just left out. The cover is needed to keep mice from getting in the hole left by the kicker shaft and nesting I guess.
- drahotus
28 Nov 2005 20:45
thank you george!
yes, it is really heavy,i tried it when i got it out of the motor.also i don't use very much a kick starter.it is rare for me when i use it.
i think that i will get just that plate to stop mice to build a nest there....
jeff should have them maybe APE or ebay.
thank you again for your respond
draho
draho
- wiredgeorge
29 Nov 2005 05:28
Since the shaft will be out, a lot of oil will be inside that cover. I would contact APE and get a cover.
- MDawnz1
06 Dec 2005 16:22
I left mine out when I rebuilt because the son of a b**ch who stole mine(yes I got it back)engaged the kick starter while the engine was running.
BLOWS out the back of the cases
1974 Z1a, still 903
