What a expensive oil drain plug.....
  • Toge
  • Toge's Avatar Topic Author
12 Dec 2006 20:47
#99258
as my previous post, I need a new oil drain plug. However, I found on the website and it cost me $23 with shipping ........why this nut is so expensive? it's just a simple 19mm nut, nothing special design on it.....
I don't get it!!
  • donthekawguy
  • donthekawguy's Avatar
Re: What a expensive oil drain plug.....
12 Dec 2006 21:01
#99260
It has a magnet and o-ring. Oh yeah and it's better than the one you have. :P I think they make them weak so you have to replace them. BASTARDS!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
13 Dec 2006 05:31
#99277
Might give this a try for the next one. Don't know if the o-ring is included or whether a generic o-ring of correct size may be readily available from the usual local sources.
www.z1enterprises.com/detail.aspx?ID=195
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Dec 2006 06:16
#99285
Consider yourself lucky.
I did not need a new plug, but the threads in my bikes oil pan got stripped! A little trickier to fix than needing the plug.
Post edited by: rstnick, at: 2006/12/13 09:17
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • kzwolfsr
  • kzwolfsr's Avatar
13 Dec 2006 12:00
#99326
What did you mean was weak Don?
Original man of the Caribbean
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
13 Dec 2006 12:31
#99329
I'd take it to the autoparts store and see what they have in their replacement parts stock. I might also use google to see what other vehicles use a 19mm plug and visit the dealer and compare to what they have. I'm much too cheap to pay $23 for that thang :-)
  • Toge
13 Dec 2006 18:42
#99388
Bastards!???? You mean me or the nut?
  • arobsum
  • arobsum's Avatar
13 Dec 2006 19:29
#99407
i think he means the folks who make the nut!!!
  • Duck
  • Duck's Avatar
13 Dec 2006 19:35
#99414
$2 for the part and $21 for customer service ;-)
  • neilage66
  • neilage66's Avatar
14 Dec 2006 10:46
#99575
You could try this one:
tinyurl.com/y2ms6t
Foteen dolla no holla...:P
  • arobsum
  • arobsum's Avatar
14 Dec 2006 18:42
#99667
sometimes you can find the whole bottom oil pan on ebay for a few bucks. get plug and all.
  • Sorf
  • Sorf's Avatar
16 Dec 2006 15:31
#100046
If you think that's expensive, have a look at the cost of a brake lever adjustment bolt & nut! AUD$60.00 over here.:( ......Oh yeah, plus shipping.
Post edited by: Sorf, at: 2006/12/16 18:32
