cylinder installation
- roystaylor
10 Dec 2006 18:33
I've installed cylinder blocks on my kz 900 /kz1000 by relying on the bevel at the bottom of the cylinder bores to squeeze the rings into the grooves of the pistons. I sort of get them started, then kind of shove the cylinder onto the pistons with a rocking motion. Have I been doing damage by doing this? The bike runs fine, but I don't have a ring compressor. What other method should I be using if not this?
Post edited by: roystaylor, at: 2006/12/10 21:49
- ron768
Re: cylinder installation
10 Dec 2006 18:41
I have used a large hose clamp to compress the rings with lots of oil to help them slide into the cylinders and slide the clamp off.
1976 KZ900 A4 , 1977 KZ650 C1 , 1978 KZ1000LTD B1 , 1978 KZ650SR D1 , 1999 ZRX1100 C3
- reborn650
10 Dec 2006 19:13
Hey Roy. The taper on the bottom of the cylinders is called champfering. This is your best friend in engine re-assembly. Any good machine shop will do this champfer without being asked and this machining evenly compresses the rings.
It never hurts to have a buddy help you out as you can each do a couple of cylinders. Start with the inside two at TDC and use golf tees or wooden popsicle sticks to gently push the rings into their slots. Keep an eye on the ring gap stagger as per installation instruction from the manufacturer.
Cheers-COlin Firth-Ontario Canada
1977Kz650 Custom - 810 Wiseco with lottsa go-fast goodies tucked away inside. A bit of a wolf in sheep's clothing.
-1998 Jeep TJ Wrangler 4.0...
