GPz750 Slotted Cam Sprockets
- svt522
23 Nov 2005 14:24
Does any one know of a vendor that sells slotted cam sprockets for a 1982 GPz750? Thanks for any replies.
- steell
Re: GPz750 Slotted Cam Sprockets
23 Nov 2005 17:51
I don't know of anyone selling them, but you could take them to a machine shop and have them slotted, or even do it yourself with a rat tail file. If you shave .040" off the head, then you need to elongate the bolt holes by .040". A little more won't hurt anything, but be sure to use loctite on the bolts once you have the cams retimed.
Actually, after thinking about it for a couple seconds I realized that the holes need to be elongated a little less than .040" because they are on a smaller diameter than the sprocket teeth. It really don't make much difference, but I figured I'd correct myself before someone else did
Post edited by: steell, at: 2005/11/23 20:57
- svt522
26 Nov 2005 04:46
I kind of thought I would have to slot the stock sprockets. I have access to a machine shop at work...I just thought I'd ask if the after market had any before I milled on the stock ones!
- steell
26 Nov 2005 06:00
How much did you mill off the head, and did you do it yourself on a mill at work?
Use a face mill or a flycutter?
