what can fit on 77 kz650b-1
- steveo_4192003
- 77kz650b-1
10 Dec 2006 15:24
i see a honda 750 dragster in my home town for sale!
iv seen it and heard it to, very nice sound...and fast!
i want to know if i can adapt the swing arm to my bike and maybe the ignition and air shifter..
its a 1970 cb750 built as drag bike
ill go look and ask more info and ect... i want to know ( got a list) things i should ask him, does anyone have any suggestions what to ask?
or is it a wast of time ???
thanks steveo
thanks steveo
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- 77KZ650
Re: what can fit on 77 kz650b-1
10 Dec 2006 16:53
you should be able to modify the swingarm to fit. (Ive got a zx636 arm on mine) Im guessing its longer and allows a fat wheel/tire, and thats what you are after right? ask him what the diameter of the povot bolt is, how wide the arm is at the pivot point(this will determine how much work will need to be done to the arm and or your frame to get it all to fit), how long it is. Im not sure if the ignition will swap, what brand and model is it? the air shifter should be able to bolt on without too much effort, maybe a custom bracket, and wire/plumb it. where are you planning on putting the air tank?
Scott
Scott
07 MDP Rookie of the Year
