clylinderb stud
  • kz-mtd
  • kz-mtd's Avatar Topic Author
clylinderb stud
06 Dec 2006 13:36
#97865
:blink: how do Iremove cylinder studs:unsure: I bought a tool for the job and it does not work:whistle:
  • APE Jay
  • APE Jay's Avatar
Re: clylinderb stud
06 Dec 2006 14:36
#97875
Does the tool grab the stud? If so, smack the top of each stud with a hammer to shock ther threads loose in the case. Careful you don't miss and hit something else and damage it.
Be sure to put the stud puller as close to the bottom as possible to help prevent twisting the stud.
Good luck.
Jay
  • kz-mtd
Re: clylinderb stud
06 Dec 2006 15:51
#97890
Good luck.
Jay
Not like I thought it would...It just spins around:blink:
  • wireman
  • wireman's Avatar
Re: clylinderb stud
06 Dec 2006 16:31
#97899
flip it over the other way;)
Post edited by: wireman, at: 2006/12/06 19:54
  • wireman
  • wireman's Avatar
Re: clylinderb stud
06 Dec 2006 16:55
#97906
wireman wrote:
flip it over the other way;) <br><br>Post edited by: wireman, at: 2006/12/06 19:54
or if all else fails call her:whistle:
  • kz-mtd
Re: clylinderb stud
06 Dec 2006 19:18
#97934
Same tool I have I :huh: I would like to say that is a nice monkey wrench:blush: :whistle:
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: clylinderb stud
08 Dec 2006 14:07
#98292
Can we flip her over the other way? ;) That is after trying it the "usual" way.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: clylinderb stud
08 Dec 2006 14:54
#98296
Good luck.
Jay
If whack no work perhaps heat to soften thread lock compound which 'might' be there? Knurled piece should bite into stud. You may have to apply a little pressure directly to it until it bites. If it's a POC AKA POS the knurling will bend and slide on the stud and you'd best return the tool in exchange for your $. Implied warranty is that a tool be suitable for advertised use.
-Duck
  • kz-mtd
Re: clylinderb stud
08 Dec 2006 19:44
#98369
Tough job but I have it done now... I hate to see what it'll be like installing them:sick:
  • APE Jay
  • APE Jay's Avatar
Re: clylinderb stud
08 Dec 2006 23:44
#98394
Installing then is a cake walk with a stud installation tool.
www.aperaceparts.com/tools.html
