Honing and need new rings
  • kzwolfsr
  • kzwolfsr's Avatar Topic Author
06 Dec 2006 06:37
#97787
Whats up guys? I have too pull off my head and possibly just hone my cylinders and maybe get new rings. First if I only have to hone, what pattern is best to use or to say what would be a good honing angle? Also I can only get the hone without the beads, Napa only has a bladed type of thing I never seen before, but o well. Also with boring the cylinders, I see I would have to get a bigger piston( I am praying its just honing I have to do). So My question is whats a good cross hatch pattern ?
Original man of the Caribbean
  • trippivot
  • trippivot's Avatar
Re: Honing and need new rings
06 Dec 2006 06:40
#97790
with the newer oils we have available 45- 60 degree crosshatch will work fine.
some years ago we did a 20-30 degree pattern to hold the oil film up longer.
  • kzwolfsr
06 Dec 2006 06:44
#97791
Ok thats what I thought.When I had the engine apart the clinders where fine with no bulges or scratches anywhere and now all of a sudden I now compression But I will see what going on when I take off the head saturday.
  • floridamba
  • floridamba's Avatar
06 Dec 2006 08:29
#97811
Are you having low compression? A compression test with some oil will tell if its the rings. If it's the rings, you may need to measure the clearance in the bore between the piston and cylinder.
If it's out of spec, honing won't help and you would need to bore it out.
What model of bike is it? I have a cylinder block and pistons with low miles on them for a kz1000 J
  • rammy
  • rammy's Avatar
06 Dec 2006 09:08
#97815
Just to let you know if you are just honeing the cylinders and replacing the rings for a stock bore on the 650 in your sign line do some checking replacement rings for stock bore are next to impossible to find new and if you do find them you will need your first 2 born children and both your nuts to pay for them.I found that out the hard way last year. Good Luck.
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
  • wiredgeorge
  • wiredgeorge's Avatar
06 Dec 2006 09:42
#97822
Have you checked valve clearances recently? Tight valves cause compression loss.
  • OKC_Kent
  • OKC_Kent's Avatar
06 Dec 2006 10:02
#97830
I wonder if the rings from a KZ1300 would fit a 650 piston? I believe the bore is the same at 62mm... but I wouldn't know any other way to check unless you had a set to measure and fit to your piston. My Zedder cross reference software says the part numbers are different. I wonder how much different...If the ring thickness were the same and the end gaps were in range, why wouldn't they work?
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
06 Dec 2006 11:52
#97845
totalseal.com has a ring cross reference chart with some dimensions in their MC catalog. might be worth scouting them and all the other manufacturers listed in their cross. 1300 rings are hard to find too.
  • kzwolfsr
06 Dec 2006 13:17
#97861
To floridamba I have a sr650, hence the signature, to George I will do all of that on Saturday. I have to take the head off to change my valve oil seal or the other thing I can't rememeber rite now. After the head is off I will be able to do all of that, a whole lot better. Is the other guy trying to tell me that rings are hard to find? What about Jeff? Doesn't he have rings to fit?:( I hope. Answer this questoin though WG, could the clearances both decrease or increase depending on where your shims are located?
  • OKC_Kent
  • OKC_Kent's Avatar
06 Dec 2006 13:42
#97867
I guess! This NOS set went for $173
Well it may not be that bad considering I recently bought a single piston ring set for a Honda 650 for $27 +shipping
Thanks for the totalseal site Duck
Cashion, OK
  • APE Jay
  • APE Jay's Avatar
06 Dec 2006 14:33
#97874
If the head is still on, do a leakdown test to find out if it is leaking and where.
As for the cylinders, have them measured for roundness before you do anything like buy expensive rings.
Jay
  • kawsakiman
  • kawsakiman's Avatar
06 Dec 2006 15:02
#97881
i agree with ape jay to check for out of round before buying rings. but z1enterprises had a set earlier this year. i shot him a e-mail and he said he had a set that a customer ordered and never picked up so they might still be floating around. but what the hell, if your that far into it a 700 kit is not to much more, go bigger and after a good hone job you'll be assured the cylinders are true and have a good cross hatch pattern on them. then like wg said, set the valvelash and enjoy the newfound power. good luck!
