need more help guys
  • Brown
  • Brown's Avatar Topic Author
need more help guys
05 Dec 2006 07:55
#97581
i've some 38mm flatslides would a 1197kit or 1385kit be best with them carbs here is the rest 410cam,head work 37.5/33 valves,sidewinder exh,trans undercut,crank welded,clutch basket welded,dyna 2000 ign sys
Post edited by: Brown, at: 2006/12/05 10:56
  • kyradawg
  • kyradawg's Avatar
Re: need more help guys
05 Dec 2006 08:02
#97583
Im thinking they would better suit the big motor?
Peace&Love:side: , Darren
  • wireman
  • wireman's Avatar
05 Dec 2006 08:18
#97588
what are you using it for?;)
  • Brown
05 Dec 2006 08:56
#97593
will use it for street mostly i know 38mm's alittle big but could not pass up the deal i traded some auto repair work for them;) B) :)tune-up & INSTALL CV SHAFT
Post edited by: Brown, at: 2006/12/05 11:58
  • wireman
  • wireman's Avatar
05 Dec 2006 09:02
#97594
i personally wouldnt run the 38s unless its a dragbike where youve got the throttle comstantly pinned !i had a set on on my 1327 andwasnt too happy with them on a streetbike,id suggest some 34 flatslides or something in that area;)
