Sleeve removal
- kz-mtd
Sleeve removal
04 Dec 2006 12:43
1976 kz 900 , how do I remove the sleeves out the cylinder block? ready to send it out.
- Duck
- e vica na i sau na ga
Re: Sleeve removal
04 Dec 2006 12:57
Aluminum expands twice as much as steel when heated. 450 degree oven should make the hole a bit larger than the sleeve.
- kz-mtd
Re: Sleeve removal
04 Dec 2006 14:49
It is like butter baby:woohoo: YA GOTTA LOVE THIS WEB SITEB)
- wireman
Re: Sleeve removal
04 Dec 2006 15:25
yeah just dont let solomrus hand you a towel to pull of the oven with a hole where your finger goes!
- kz-mtd
Re: Sleeve removal
04 Dec 2006 20:08
wireman wrote:
I had to do it while the wifee was out:whistle:yeah just dont let solomrus hand you a towel to pull of the oven with a hole where your finger goes!
- kzwolfsr
Re: Sleeve removal
06 Dec 2006 06:47
Are the sleeves removable out of my 650 also?
Original man of the Caribbean
- 77KZ650
Re: Sleeve removal
06 Dec 2006 06:54
yup, steel sleeves in an aluminum block. use the same trick.
worried that they will be worn out when you take it apart?
Post edited by: 77KZ650, at: 2006/12/06 09:57
07 MDP Rookie of the Year
- APE Jay
Re: Sleeve removal
06 Dec 2006 14:38
kz-mtd wrote:
Were you allowed back in the house after she came home? Did it smoke the whole place up?
Jay
wireman wrote:I had to do it while the wifee was out:whistle:yeah just dont let solomrus hand you a towel to pull of the oven with a hole where your finger goes!
Jay
- kz-mtd
Re: Sleeve removal
06 Dec 2006 15:48
APE Jay wrote:
It took about five to ten minutes and that's it :side: I cleaned it for the most part so it could not really produce a smell:whistle:kz-mtd wrote:wireman wrote:I had to do it while the wifee was out:whistle:yeah just dont let solomrus hand you a towel to pull of the oven with a hole where your finger goes!
Jay
- wireman
Re: Sleeve removal
06 Dec 2006 16:30
russ's wife smelled it as soon as she got out of her car!:whistle:
- kawsakiman
Re: Sleeve removal
06 Dec 2006 17:49
a good bbq grill also works. it keeps you in the good graces of your spouse and leaves a nice smokey taste when your done. then you can use the dishwasher as a parts cleaner.
#1 strip parts of all rubber parts and gasket material
#2 fill dishwasher with purple power and insert parts
#3 stop halfway through to get a good soak going then restart
#4 while dishwasher is on it's drying mode, run to store and buy flowers and diamonds because you are getting caught for sure.
#5 wait till she leaves and repeat as nessessary
#6 thank her for understanding the kz obsession we are all guilty of and promise never to do dumb sh#t like this again.
(btw, never use the bathtub as a parts washer, that is just to redneck and wrong in so many ways)
