Oil drain nut
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
Oil drain nut
04 Dec 2006 11:46
I havent started on my 78 KZ1000 A1 yet but I have a 82 KZ1100 parts bike and having problem with the oil plug is it stuck or is it a revers thred that loosens clock wise?
- mariozappa
Re: Oil drain nut
04 Dec 2006 13:23
Not reversed. Sound stuck...apply heat!
1977 KZ650C1
and the KZ650/KZ750 Conversion
- Sandy
- Fly High,Tony
Re: Oil drain nut
04 Dec 2006 17:23
What He said.No reverse threads.
And Wagonmaster...The "78" KZ1000 is the A-2 model,btw,Bud...just thought You should know that.
The "77" is the A-1 model.
(or maybe it was just a typo)
1977 KZ1000 A-1
- wagonmaster69
Re: Oil drain nut
04 Dec 2006 22:59
A yea I knew that:whistle: makeing sh
ure all you guys knew it:woohoo: thanks for the info guys.
And on the A-2 thanks Sandy
:huh: Still got to stop looken at it and start wrenchen on it;)
- Sandy
- Fly High,Tony
Re: Oil drain nut
05 Dec 2006 18:38
So get off Your a**,and grab some wrenches!
THERE...that was Your motivation!
I hear what You're saying though.I find it hard to get MY projects started too.:laugh:
1977 KZ1000 A-1
- donthekawguy
Re: Oil drain nut
06 Dec 2006 00:41
It took me two hours and a pipe wrench last time to get miine out. Good thing I got a new one from Jeff before I started!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- trippivot
Re: Oil drain nut
06 Dec 2006 06:56
shock - hit the threaded fastener with hammer and drift.
that is the secret to releasing steel and aluminium or alum.-alum. threads from each other.
be careful, it takes a bit of experience to know how hard to hit the stuck bolt.
heat works better on steel to steel, and is a second choice when working with non ferris materials.
- kzwolfsr
Re: Oil drain nut
06 Dec 2006 18:29
Just get a breaker bar, make sure you are going in the right direction. Use the breaker bar for more leverage, If you try knocking it you might knock your eye out, thats if you dont have experience like maself
Original man of the Caribbean
