1200cc piston 76mm
- gpzbob
1200cc piston 76mm
02 Dec 2006 03:07
hello
i have 76mm arias pistons in my dragbike. dropped a valve in one cylinder no damage to the cylinder but the piston is trashed. my question is can i run another brand piston without boring? arias doesn't have that piston anymore
- APE Jay
Re: 1200cc piston 76mm
02 Dec 2006 09:17
Are you talking about just replacing the one piston with another brand, or complete new set?
Arias made both silicon and non silicon pistons. The silicon's took a smaller bore. If your bores are small enough, and are round, you could put new ones in with a hone to fit.
Jay
Jay
- gpzbob
02 Dec 2006 12:25
i can't just change one piston can i? will mtc or je pistons be close to what the arias pistons were? do i need to do another block?
- wireman
02 Dec 2006 12:53
im guessing those pistons are machined and balanced pretty closely as a set and throwing in a piston from a differant manufacturer might really throw things off.not to mention if the domes arent exactly same you could end up with differant compression on one cylinder and differant rings ,i wouldnt reccomend it myself but Jay wouldbe the one id listen to;) goodluck,happy wrenching!
- oldkaw79
02 Dec 2006 15:43
I would contact JE pistons. They can custom make any piston. The biggest thing is the weight of the piston.
- gpzbob
03 Dec 2006 07:37
new question whats the power difference between 1015 12.5 to 1 and 1200 12.5 to 1
- wireman
03 Dec 2006 08:24
if you can put it to ground and keep the bores round it should be quite a differance!:evil:
- APE Jay
03 Dec 2006 18:53
oldkaw79 wrote:
One custom JE, provided they would make only one, would cost as much as a new set of Wisecos.
Jay
Jay
- gpzbob
- 77KZ650
04 Dec 2006 17:36
if you can find another brand that is the same weight, and same compression ratio, I would go for it, but if not, I would try and sell the good ones (to someone who did the same thing you did) and buy some wisecos
Scott
Scott
07 MDP Rookie of the Year
