Wisco head gasket?
  • hardr0ck68
  • hardr0ck68's Avatar Topic Author
  • Who put the what in the where?
Wisco head gasket?
01 Dec 2006 22:36
#96705
Do you need to use the Wisco head gasket with a 700 kit (for the kz 650) or do you still use the factory head gasket?
I want to pick up extra rings and head gaskets when i buy the kit.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • Mark Wing
  • Mark Wing's Avatar
Re: Wisco head gasket?
01 Dec 2006 23:31
#96720
Either will work. I thought the wisco kits came with a copper head gasket which is reuseable.
Mark
Yorba Linda Cal.
  • APE Jay
  • APE Jay's Avatar
01 Dec 2006 23:47
#96722
Be sure that the pistons are not contacting the gasket if you use a stocker.
Jay
  • 77KZ650
  • 77KZ650's Avatar
02 Dec 2006 02:24
#96726
my 810 kit came with a fiber gasket(with steel rings) I think its supposed to be a cometech(sp?)
if you use a copper one, just put it on the cylinders after they are bored and match the holes up by taking some material away with a die grinder or dremmel;)
Scott
07 MDP Rookie of the Year
