Having trouble starting
  • Eric12775
  • Eric12775's Avatar Topic Author
26 Nov 2006 07:42
#95022
I have a 78 KZ650 and I rode it all last summer but I'm having trouble getting it started to drive it to the storage site. I pulled the plugs, cleaned them up, checked to see if I'm getting spark (they are), and I'm still not starting. Carbs were cleaned in AUG and I'm wondering if I can use a starting agent like ether or starting fluid? Please help me because its prolly going to be the last good day here in Michigan.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Having trouble starting
26 Nov 2006 08:15
#95032
Are you getting fuel? Can you drop the float bowls and see if the needle valves are allowing the bowls to fill up?
"Carbs cleaned in August" I'll bet the problem's related to the carb cleaning.
Good Luck
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
26 Nov 2006 09:06
#95044
Are you using the Choke?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Eric12775
26 Nov 2006 09:29
#95050
I was. Should I be using it? I was told too much choke is bad.
  • wiredgeorge
  • wiredgeorge's Avatar
26 Nov 2006 11:14
#95071
The carbs on your bike require a richer air/fuel mix in order to start than is needed once the bike is warmed up. Put the bike on full choke and don't twist the throttle as that only floods the carbs. Hit the starter button briefly and then let off. Repeat till it starts. Once the bike starts, allow the bike to warm FULLY before setting the idle. If the bike still doesn't start, the cleaning was inadquate. The choke system and pilot system need to be cleaned. Also, if you have mucked with the factory airbox/filter and/or pipes, the mixture will likely be somewhat leaner than when it came from the factory and the bike will be even harder to start than it should be. Last, you can be getting arcing in the plug caps. Try spraying inside the plug caps with contact cleaner and then put a dab of dielectic grease in there. This eliminates the moisture which causes shorting and hard starting.
  • Eric12775
26 Nov 2006 18:27
#95181
Hey guys thanks. Got it started and put away in storage. My dad has a heated garage and he can start it every week when he lets his Goldwing run. Thanks again guys.
