This is just so complicated to explain, that I doubt I can do it before my two typing fingers fall off
First off, ignition is advanced as the rpm increases (up to around 3600-3800 rpm) so that the mixture will have time to burn before the piston reaches BDC. If you have to retard the ignition to compensate for the higher compression ratio, you will loose power compared to a lower compression ratio with proper timing.
Secondly, calculated compression ratio is only useful for bragging rights, dynamic ratio is all that matters. It is entirely possible to build a motor with 10:1 calculated compression ratio that has a higher dynamic compression ratio (and has to run higher octane or less advance) than a 13:1 motor.
Third, the upper limit on dynamic compression ratio is the amount of heat that the cylinder and head can transfer to the surrounding air, and the octane of the available fuel.
In no particular order:
Cylinder filling is a very important factor in determining maximum compression ratio, with 24mm carbs on a 1170 motor you can probably get away with a 13:1 ratio on pump gas, as long as you keep the rpm above 5k. The small carbs will restrict the cylinder from filling completely and result in a lower dynamic ratio. The same thing applies to cams with lots of overlap, or that delay intake closing, the first allows mixture out the exhaust while the second pumps it back into the intake, Chevrolet used the second method in their hot rod 360-375 hp 350's in the late 60's and early 70's.
Combustion chamber design has a lot to do with it as well, the combustion chamber in the Jaguar V12 HE motors allowed them to run a 12.5:1 ratio on pump gas. The hemi chamber in the KZ's is pretty much the worst kind to use for high compression.
And I'm not even going to get into rod length ratio and it's effect.
Best advice I can give is to stick with proven combo's, unless you have the time, money, and facilities to do the research involved to extend the "Bleeding Edge" of technology
There is a whole lot more that could be said on the subject, but my two typing fingers hurt
I just remembered that
Speedomotive
has some info on the subject.
Post edited by: steell, at: 2006/11/24 12:46
