Stripped the oil drain plug hole
  • JR
  • JR's Avatar Topic Author
Re: Stripped the oil drain plug hole- update
24 Mar 2007 17:09
#123168
Patton wrote:
Is heli-coil no longer an option? :)
I've never used a helicoil before. I never thought of that today. Maybe it's time I learned :)
  • Bluemeanie
  • Bluemeanie's Avatar
24 Mar 2007 17:28
#123172
Mine stripped out also, pulled pan (kerker also)drilled and tapped to next larger size. Found out I drilled slightly angled! Now every oil change I wrap threads with teflon tape and install a new fiber washer (bought plenty) Has worked great for 10 years but it bugs me so will be checking ebay for replacement pan. Really the proper way to fix that is to pull the pan and either do as I did or helicoil it, both of which require drilling. Can be done on bike but really iffy with the shavings flying around! Good luck.
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
24 Mar 2007 21:06
#123217
Sounds like now would be a good time to upgrade to a GPz750 oil pan and cooler. ;)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • 74cb750
  • 74cb750's Avatar
25 Mar 2007 05:08
#123256
Need an oilpan? for what year/bike?
michel
It is still to cold to ride!
  • JR
25 Mar 2007 06:20
#123265
1980 kz750 E1
  • donthekawguy
  • donthekawguy's Avatar
26 Mar 2007 00:44
#123534
Get a new pan. Cheap,easy -correct fix.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • ScottZ
  • ScottZ's Avatar
10 Jun 2007 12:05
#148046
Don't like to dredge up old posts, but does anyone know where to pick up one of these universal winged drain plugs? I've searched the web and can't seem to find anything..
10 Jun 2007 12:42
#148051
Auto parts stores sometimes have them, but a hardware or plumbing supply specialty store will be more apt to carry them.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
