Clutch Cable
- Shoey949
Clutch Cable
19 Nov 2006 10:32
Alright I have a bit of an issue. I have snapped my clutch cable and I am now looking to buy a new one to install over Thanksgiving break. However I am not sure if I should get an '81 cable or an '83 cable, since the whole bike is an '83 except for the engine and carbs. So what shall I do?
Thanks,
Nate
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- Sandy
- Fly High,Tony
Re: Clutch Cable
19 Nov 2006 11:37
Nate...the cable You have on the bike now...how is it for length and how is it routed?
I don't know the differences in the 2 bikes,but the main concern would be that the cable is long enough(but not too long)to be routed properly,with no sharp bends in it,creating stress on the cable itself.
I'm assuming that You don't know what cable You HAVE on there now,so that's where You'd have to start.
I wonder if Jeff(Z1 Enterprizes) might be able to get You some measurements...I know He had them listed on His site for the KZ's.
Or...find a Member who has the same bike and get Them to measure Their cable?...
1977 KZ1000 A-1
- JMKZHI
Last edit: 03 Dec 2008 11:33 by JMKZHI.
- Sandy
- Fly High,Tony
Re: Clutch Cable
19 Nov 2006 12:34
JMKZHI wrote:
Well then...there Ya have it!:laugh:
Z1Enterprises.com has the cables w photos & measurements - total length & slack. Make sure the ends are correct for your bike. My preference - for now anyway - is the oem cable. The spring type shroud over the lower section of some of the afteremarket clutch cables is larger in diameter & doesn't fit well in the oem frame cable clamps - to me anyway. The oem spring is more snug around the outer black sheath.
JMK.
1977 KZ1000 A-1
