Zephyr 750 motor into a Z500 frame?
- schambers
17 Nov 2006 15:23
After trying to find ways to tart up my Z500 motor, I have found a Zephyr 750 motor fairly cheap.
Anyone done this swap, or know someone who has?
I will go to the wreckers and measure, buy knowing it had been done before would help.
Thanks, Steve
Thanks, Steve
- jimmybon
Re: Zephyr 750 motor into a Z500 frame?
18 Nov 2006 16:12
giday Steve, I'm up in sydaney and have put a zr750 (zephyr) engine in a z650 chassie. I thing if some one has put a z650, or z750 engine into the z500 chassie then the zr could be done
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- Mcdroid
- Gone Kwackers
19 Nov 2006 03:48
Steve, I think that the reason few people have responded is that not many KZR members have owned Z500's (not to mention seen one). The bike was never released in North America (where most of the members are). The Z500 is however, similar to the KZ550 and I am unaware of anyone shoe-horning a larger displacement motor into a 550 frame (this is not to say it hasn't been done). Swaps between 650 and 750 bikes are common...and there have even been a few 900/1000 motors wedged into 650/750 frames.
Post edited by: Mcdroid, at: 2006/11/19 06:50
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- schambers
19 Nov 2006 15:56
Thanks for the response. The 550 was released here after the 500, and was basically the same. After measuring the Zephyr motor, it would not fit in. I'll look for a Z750 motor, which is older technonogy, but a direct swap.
- 77KZ650
19 Nov 2006 16:12
schambers wrote:
do you mean wont fit the motor mounts or wont actually fit into the frame? if it doesnt line up with the mounts, but it can be crammed into the frame, you could just make some custom motor mounts and weld them on (thats how the guys that do the 1000/1100 motor in the 650/750 frames do it)
Scott
Scott
07 MDP Rookie of the Year
- steell
19 Nov 2006 16:33
The air cooled Zephyr 750 is close enough to the earlier air cooled 750's that most if not all parts interchange, so if the earlier 750 will fit then the Zephyr 750 should fit as well.
That's assuming the Zephyr 750 where you are is the same one we have in the US.
- loudhvx
19 Nov 2006 23:48
The earlier 750 is the same size as the 650, for the most part, but it's definitely not a direct swap into a z500/550 frame. I'd still look for a gpz550 motor. That will be a direct swap into the z500 frame.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
