Engine noise suddenly disappeared....?
- Biquetoast
- King Jeremy The Wicked
17 Nov 2006 05:43
My current commuter 750 has always had a certain engine noise, ever since I got it two years ago. The noise is a bit of a diesel-like sound, not loud and really only there at low rpm and under initial acceleration .
I figured it's just a valve with excessive clearance (I intend to check the valves this winter), because I checked the camchain tensioner and it was well-adjusted. In fact, the whole bike was pretty much un-abused though neglected, sitting in a storage bin from '93 to '04. I've put ~2000 miles on it since purchase, and it still only has just over 10K miles on it.
On my regular hour-long commute this morning, I stopped at Dunkin Donuts at about the halfway point. When I left from there, at the next light, I noticed the engine no longer makes the sound. It still runs great, but I mean it's just suddenly quiet. It's not like it faded over time, it just stopped.
So at the next light, I hurried through the gears with heavier acceleration at low rpm to see if the noise was still eveident. Nope. Quiet. Running great. In fact, it seems to have more power.
What the heck?
:huh:
Post edited by: Biquetoast, at: 2006/11/17 10:47
What the heck?
:huh:
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- arai59
Re: Engine noise suddenly disappeared....?
17 Nov 2006 05:46
When was your last tune up ? Ignition timing ?
- flht1997
17 Nov 2006 06:01
did you happen to put ear plugs in?
my bikes run 100 times better as soon as i plug my ears.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Biquetoast
17 Nov 2006 06:02
arai59 wrote:
I did that all early this year. Everything is gone over (carbs, new coil, ignition, etc) except valves.When was your last tune up ? Ignition timing ?
kz750twins.com
kz750twins.com
- Biquetoast
17 Nov 2006 06:04
flht1997 wrote:
No ear plugs. I mean, even if I did, I would still hear the diesel-like noise, just quieter. But the noise is gone.
My hunch is that The valve clearance has suddenly changed, but not in a apparently damaging way. Oh.... I wonder if a bolt snapped inside... like a camshaft bolt.. crap, I have to ride home still....
Well, it's really not running any different, if maybe a tad better. That could be an illusion on my part, since there is no noise.did you happen to put ear plugs in?my bikes run 100 times better as soon as i plug my ears.
kz750twins.com
kz750twins.com
- Pterosaur
17 Nov 2006 06:20
Biquetoast wrote:
Using 89 or 94 gas lately? Maybe the station you frequent quit dumping ethanol down the filler pipes at 3am.
Sounds like a (minor) detonation issue.
Valve/shim noise is usually loudest right at idle - or a little above.
Hard to guess which "diesel-like" sound you're referring to - they're such noisy critters to begin with... :lol:
My current commuter 750 has always had a certain engine noise, ever since I got it two years ago. The noise is a bit of a diesel-like sound, not loud and really only there under acceleration at low rpm.
- Biquetoast
17 Nov 2006 07:03
Pterosaur wrote:
It is pretty hard to describe the sound. I chose "diesel-like" bacause it's pretty good and I've heard other people mention it. Thought it might ring a bell or two...
Detonation, huh? Hmm. You mean pinging, right? I don't *think* it's that, because it make the sound with every revolution, even at idle, but was *most* prominent at acceleration at low rpm. Remember, lots of low end on these 750, so I'm talking about "getting on it" at 1200-2000 rpm...
Oh, and gas is 87 US Octane. Regular. Always.
Also, it was about 35F degrees at the time it happened. Or stopped happening, as the case may be...
...Using 89 or 94 gas lately? Maybe the station you frequent quit dumping ethanol down the filler pipes at 3am.
kz750twins.com
kz750twins.com
- geerbangr
17 Nov 2006 07:35
If the noise went away the problem fixed itself(that's the way my dumbass boss thinks).
:dry: :S :huh: :whistle:
1978 KZ 1000
I go by Jason
I go by Jason
- The Milkman
17 Nov 2006 10:51
Quick thought, it may have been your timing advance unit was stuck in one position and it finally broke loose.
Ride safe,
Les
Ride safe,
Les
- loudhvx
17 Nov 2006 11:10
I hope it wasn't a timing chain guide that was loose and is now broken.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- hmondo
17 Nov 2006 11:47
It's got to be the "KAWASAKI GODS" smiling down upon you! In other word...you dun bin blesd.
Happy Ridin'
Happy Ridin'
1989 KZ1000 P-8 (Police)
1987 ZL1000
1986 Concours (Project Bike)
1987 ZL1000
- Biquetoast
17 Nov 2006 12:33
Thanks for all the suggestions, guys. I think what I'll do is just do an oil change and put 'er up for the winter when I get home. Then later I can check the valves - I was going to anyway - and see if something's goofy.
I hope I make it home today...
It just sounds like there was one really noisy valve/cam lobe/shim/etc that suddenly got quiet.... That just can't be normal...
kz750twins.com
kz750twins.com
