KZ750 Twin
  • CSR1000_Mike
  • CSR1000_Mike's Avatar Topic Author
KZ750 Twin
15 Nov 2006 05:48
#92251
I have a general KZ750 Twin question - a friend of mine just bought one and has been working on it to get it ready to ride. The bike is titled as a '78, but the VIN says it is a KZ750 B2 - the Kawasaki site and others say a B2 is a 1977 model and a '78 is a B3, but also according to the factory parts diagrams, it has the B3 style front master cylinder for instance like a '78 should have. It is also green if that means anything. It at least appears to be all original and only shows 9300 miles. The MFG data is 7/77. Anyone have any ideas on what it really is since there seem to be a number of part differences between the B2 and B3???
1983 Kawasaki KZ1100 LTD
1978 Honda CB550 project
1973 Yamaha TX650 project
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: KZ750 Twin
15 Nov 2006 06:59
#92265
I had a bike dealer once say that July was the cut date for the new model years ,Not Sept like cars , so it could be a early 78 ,, There are a couple serious twin guys on here so if you need anything or help in anyway I am sure it can be answered ,, :)
Post edited by: Shoe48, at: 2006/11/15 10:00
  • steell
  • steell's Avatar
Re: KZ750 Twin
15 Nov 2006 07:00
#92267
7/77 would be a 78 model (I think I have one manufactured in 7/77).
Master cylinder top on the 78 is kinda rectangular while 76-77 is round, charging system on 78-79 is permanent magnet with solid state reg/rec while 76-77 has a coil and separate reg and rec. Carbs may have minor differences (but I'm not sure).
VIN on frame match VIN on title?
Lots of parts have been updated on these bikes by previous owners over the years.
  • CSR1000_Mike
Re: KZ750 Twin
15 Nov 2006 07:11
#92272
Yes, the VIN on the frame matches the title.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: KZ750 Twin
15 Nov 2006 13:08
#92340
CSR1000_Mike wrote:
....The bike is titled as a '78, but the VIN says it is a KZ750 B2....
A common misconception.
The "2" in "750B2" in the VIN does not indicate model number, rather it is the first digit of a numerical sequence.
You have a '78 B3.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • agawam
  • agawam's Avatar
Re: KZ750 Twin
15 Nov 2006 20:40
#92480
I own a 79 B, and just got a 78 for parts I also had oppertunity to look over a 77 fairly close, while these are the same model there are a lot of differences, the frame on my 79 is not the same as the 78, basically it is but where the engine mount on top and coil mounts are different, tank rear mount (rubber strap) is different, the 77 has a different harness and components.but I suppose at the end of year run a lot of bikes got the inbetween treatment as many kawasaki models did and sometimes it can confusing as to which model you have
  • SpokeWheel650B
  • SpokeWheel650B's Avatar
Re: KZ750 Twin
15 Nov 2006 20:45
#92482
Not to confuse things further :blink: but my KZ650B has a MFG date of 6/77 but is a '78 B2 for sure. Sorry if this doesn't help:whistle:
