valve cover swap?
- wiredgeorge
valve cover swap?
20 Nov 2005 14:49
Picked up 1979 KZ1000E (ST) this weekend. Will the valve cover from an earlier KZ/Z fit if I don't use any of the hoses? I have extra covers... I already know I can block off the nozzles on the stock valve cover if they are not used or run a hose between them but I don't like the look of doing that and using a cover I already have would be cheaper than buying APE block-off plates. Thanks!
- Jeff.Saunders
Re: valve cover swap?
20 Nov 2005 15:26
If you switch covers, you'll get exhaust flames toasting the underside of the tank unless you weld up the emissions ports...
www.z1enterprises.com
Z1 Ent on Facebook,
- bob_z1
20 Nov 2005 17:02
you don't need to weld them... just tap them with a pipe tap and put pipe plugs in the holes.
Post edited by: bob_z1, at: 2005/11/20 20:03
- DasTeufel
20 Nov 2005 17:03
pretty much what I did on my 550
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
Wildomar, CA
- 79MKII
- Love Them Kaws!
20 Nov 2005 18:59
bob_z1 wrote:
I've always wondered about this...do you have to remove the head to tap the holes? Wouldn't the shavings make their way into the head? I'd like to do it myself but I'm wondering if I have to wait until the head is off again.
you don't need to weld them... just tap them with a pipe tap and put pipe plugs in the holes.<br><br>Post edited by: bob_z1, at: 2005/11/20 20:03
The Kaw List:
- Mark Whiddon
21 Nov 2005 12:21
Don't know about the swap, but I just bought some 1/4" aluminum plate and used my mill to make my own emissions cover. cost about $10 and a bit of time.
Mark
Mark
- hat0791
21 Nov 2005 13:03
Just out of curiosity, why are you swapping the covers?
- bob_z1
21 Nov 2005 13:42
79MKII wrote:
well you are asking someone who has repaired spark plug threads with the head on so maybe I'm not a reliable source.... I just load the tap with grease to catch the chips and then use a shop vac with a small end to get anything that falls.
:ohmy:
:ohmy:
