that's what i had hoped for by going with the 29's. i want it responsive, but no need for the big flow of 34's.
you pretty much summed up what i am planning to do for the port work. clean up the runners, match inlets to the 29's with a good taper(not TOO much), try to hit the 29mm csa that you talked about in your other posting, mild bowl re-work, and pulling the throat out. i was planning for 88-90%. 8^)
no real plan for more carbs later on.
here's my reality with the parts selection: wireman is putting up the parts for me... the 435s were clanking around under his bed, the block, heads, pistons are doing mock-up duty, so they might as well be put to use in my engine. i'll be picking up sleeves, rings, and top end seals/gaskets.
setting up an oil cooler, and the rest is chassis work.
durability is priority 1 on this engine. it's hauling my ass and some cargo out to norcal for the motogp. i'd like it to bring me back as well. 8^) it's gonna be geared tall to eat miles. i'm projecting average speeds between 70-90mph.
larry, if i am anywhere near your location on this trip, even if i am just passing thru, i will INSIST that you take it for a spin.
it's gonna have a modern suspension on it when i am done, a less-intense frame gusseting program than wire's, 17" wheels, usd forks, radial brakes... eventually it will probably even be injected.
more info on that project in the project section.
--r
larrycavan wrote:
I see your situation with the carbs. Neither set is ideal. The 29's should yield excellent throttle response on that setup. IMO, 38's are entirelly too big for 900 port runners.
With those cams, you've got enough curtain area and flow with a stock head for roughly 7800RPM Peak HP RPM.
Now, unless you plan on going with more carb later on, there's not really much port work needed. It sounds to me like you've ported before. You could clean up the casting lines, shape the bowl a tad bit and match the seats to the ports. I'd definitely go 90% on the throat size. IMO, you could actually get away with less cam for what your goal is for the motor. K410's are about perfect for your goal.
I guess it's getting to sound like I'm a K410 fanatic or something. It's not the case. There are 2 primary reasons I've been coming back to that grind.
1. It's the right cam numerically for the application.
2. APE has been around a good long while and I hope they continue to be. There's still life in these old 2V KZ motors, there's still a market for performmance parts.
Anyway...that's how I see it.....I'd love to take the bike for a ride when it's finished...should be lots of fun.
Larry C
